Question about Dell Inspiron 4150 Notebook
Won't boot up
Dell 4150 when i power up the unit the middle light flashes 10 times fast then the unit shut down can't even get in bios treid both memory slots nothing happens please help thanks
    Problem Solver:
  • 10 Answers
Can you give a little more information? Did the Laptop Fall? What Color is the light that blinks? Amber or Green?
So far it Sounds to me that you Power Supply is Dead or Bad and or not charging the Battery....
First Check the battery status light?
Is the Power Supply Light (Lite). you might want to try removing the battery and using only the Power supply!
Posted on Jan 15, 2008
My c400 dell latitude laptop is not booting what
If it doesn't boot at all not even to bios then Id say you got bad ram. If it boots to bios then shuts down its a heat problem and it needs to be cleaned or the fan replaced. If it boots to bios then a black screen and all lights are on then Id say hard drive. If it doesn't power on at all or lights come on but nothing else then the GPU has more than likely got to hot and solider has broken down losing connection. I haven't seen this on a dell but have seen many HPs do that.
Sep 02, 2014 | Computers & Internet
Dell desktop won't stay shut down
Here's a resource on Dell that might be of use:
Apr 10, 2012 | Dell OptiPlex GX520 PC Desktop
Fujitsu econel 100, server wont boot after trying many things i removed memory chips one by one and finally the server booted so i suspect it as faulty memory chip ok I managed to login and tinker around...
See if your fans and drives are spinning up fast enough, perhaps image a fresh drive if you can; certainly it's time to resolve BIOS state issues from discombobulating the DDR.
Er, how many DIMMs are in there now? 1? Is it good?
Jul 25, 2011 | Fujitsu Siemens PRIMERGY Econel 10...
When I plug in my inspiron 4150 the light flash and it will turn on for a short time roughly 2 mins then shut down and won't work again for quite a while. The battery is toast and has been for a while and...
Get support for your Dell product with free diagnostic tests, drivers, downloads, how-to fix, Errors, FAQs and community Dell forums. Or speak with a Dell technical Support expert by Toll-Free phone 1 (800) 204-4427 or chat. Read More... Dell Support Phone Number 1 800 204 4427
Jun 26, 2017 | Dell Inspiron 4150 Notebook
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
Aug 29, 2017 | HP Pavilion dv6928us Notebook
Probs with boot up on a Dell inspiron 530s
When booting enter the BIOS setup svreen and press the following combination
1. Alt + E
2. Alt + F
3. Alt B
this combination will rebuild the IDE configuration and clear the NVRAM. Alt + b will save the configuration.
1. Shut down PC and unplug Power cable from Back of Tower.
2. press the power button and Keep holding for 10 seconds. this will remove static charge from PC
3. Plug in cable and restart.
Jan 13, 2009 | Dell InspironTM 1501 Notebook
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Toshiba Satellite 3000
    Try going into bios utility and check to see if there is a HDD enable option. If not, find another pc and burn a bootable bios disc with the original bios.
    Jun 11, 2008 | Toshiba Satellite 3000-S353 Notebook
    Computer "A" key flashes then shuts off computer
    try to go to bios, If you can not go to bios, then its a motherboard issue, You need to replace the motherboard..
    Feb 14, 2008 | Dell Latitude D600 Notebook
    Dell Inspiron 4150 Notebook Logo
    165 people viewed this question
    Alun Cox
