Question about Tricity Bendix WDR1240W Front Load Washer / Dryer
Bendix WDS 1043M Condenser Washer-Dryer
Bought this unit used - owner said it worked fine, but I am finding that it does not dry the clothes - ran the dryer for over 90 min with 3 light shirts in it, they were still damp. is there also supposed to be a fan in this unit?? did not hear one running if there is. thank you for your assistance
  • BrstowGuy Jan 15, 2008
    I have the manual, does not address this very well - have done everything listed - and the website link in your msg does not work, it brings up a MS office demo video
    President:
  • 1,294 Answers
Click on your brand name (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 15, 2008
I have this model Bendix washer dryer, because it has no venting it drys and holds the condensed air inside, just let it run about 80 min per load then take out each item, shake well to release the condensed vapor, lay over a bed or chair for about 5 minutes.. it will be dry. That is the way it is designed to work. Enjoy
Posted on Oct 08, 2008
    Problem Solver:
  • 8 Answers
Problem's the heating element or the thermostat. Take the top off & check that the heating element's getting energized. If it's energized then the thermostat and timer are doing their jobs. Turn it off, unplug it & check the resistance of the element. If it's infinite then replace it. I found a great parts place, if you need one. Got the manual, you say? Could you scan it for me?
Posted on Aug 09, 2010
6ya staff
SOURCE:
LG Washer Dryer F1403RD low drying efficiency. Any ideas
If it’s taking a long time to dry, check venting for obstructions or kinks.
Oct 13, 2018 | Dryers
Water outlet hose replacement
Hi, you could try copper pipe, 22mm, or 3/4" (ish) ( plumbers) and jubilee (adjustable clips, from hardware store) to clamp the two together.
Dec 06, 2017 | Splendide Comb-O-matic 6200 Non-Vented...
Clothes not heating up and remain wet
ok like i said before haiers can be tricky. if you where to remove the lid 2 screws in back pull forward and remove lid. you will see a silver peice i believe you will also see the fan. That metal peice should have 2 wires on it. that is your heating element. I am going by memory so dont quote me. but if you check with no power to the unit///unplug...check the 2 wires at that silver metal peice you should have continuity there. if not your element is bad. i belive it is located to the right of the unit directly under the lid. there is also a thermistate there as well I know those thermistates are not very good. and the last time i had a haier not drying was the thermistate.I think there might be 2 orange wires going to it. I hope this helps..
Aug 14, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
WDB1043M Bendix Washer/Dryer
I had the same problem. Then I discovered that the Bendix USA WDS1043 / WDC1024 is the same, or almost the same, as a Splendide Comb-o-matic 6000. You can find an extensive parts manual at
http://www.splendide.com/service/Combo_PartsBreakDown.pdf
and an owners manual at http://www.splendide.com/manual_wdc1024m.pdf
I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at
They can also supply a replacement washer/dryer combo when your present unit finally dies.
Good luck with a great washer combo!
Colin
Jul 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Dryer
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Mar 13, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Soap dispenser box Nipple broke off. need new or repaired part
Iam sure they are they available in Ireland
Iam sure they are, I live In Ireland the parts are available here
Nov 24, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Brand new washer dryer leaking - Triciy WDR1241
Go back to dealer ,make sure it is plumed OK .close bye
Oct 08, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Tricity Bendix WDR1240W Front Load Washer / Dryer Logo
986 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
