Question about HP PSC 1410 All-In-One InkJet Printer
I cannot delete a document from the print que. It won't print and it won't delete and the printer won't print anything else until one or the other has been done. Running XP, printer is and HP PSC 1410 . Any help appreciated.
    New Friend:
  • 146 Answers
Hmm..unplug the printer from computer and power printer down. that should clear the printer memory. then plug back into computer, before turning printer power back on. see how that helps.
Posted on Nov 29, 2009
SOURCE:
How can I clear the print que? I tried to cancel printing a document, and now the que says cancelling, but won't let anything else print
1) Try to restart you system with the printer unplugged.
2) Try to Pause the printer and then delete the items in the que
3) If this doesn't help Delete the printer and re-install it.
Aug 29, 2014 | HP Photosmart C6180 All-In-One InkJet...
The file currently in the print cue won't print. I tried to cancel the print but it won't delete. I uplugged the printer, did a restart, same problem. I tried to uninstall the driver, no luck as...
Try looking on the bottom right side of your pc, near the clock to find the picture of the printer or Icon for the print Que. Sometimes you have to click on a little arrow in this area to open it up and view all available. Find the picture of the printer and right click with your mouse on top of it. choose all printers and this should bring up a list of documents which have failed to print. Find the document and click on it then choose "delete" until there are none left on the list. make sure you use the "all printers" choice and not just the one listed in the name of your printer to clear this que. if this does not work, let me know by using the comment or reply links next to your question on Fixya and I will send more troubleshooting instructions.
Sep 12, 2011 | Dell 942 All-In-One InkJet Printer
I have an HP printer. There is a full page photo that will not print. When I try to cancel the job is states deleting but does not delete. It deletes other added print jobs but not that one which is...
You have to clear out all documents one by one in the print que before you can delete the one causing the trouble. On the bottom right side of your pc screen, find the picture of the printer and right click with your mouse on it. Open your print que and right click on each document and choose "delete" until therer are none left in the print que. If this does not clear that last document, then unplug your usb cord that connects the printer to your pc and wait a few moments, and then plug it back in. This should clear it out.
Sep 08, 2010 | HP Officejet J4680 InkJet Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
a
Sep 23, 2009 | Office Equipment & Supplies
Dell 948 printer will not delete a document
try putting a sheet of paper on the printer and hit the print button..
Aug 11, 2009 | Dell 948 All-In-One InkJet Printer
I attempted to print a 25 page document, with reverse pages. Only 9 pages printed. I cannot print anything now. and the message on the printer reads, DATA REMAINING. I have pushed every button...
It seems the printer buffer memory has overflowed. Cancel the print from the print Que and switch off the printer. Give your PC a reboot too. Now switch on the printer and make sure that there is no document in the print Que. If its still there, disconnect the printer and delete the pending job, i.e. print Que. After the printer shows it ready for printing do not release the entire document for printing at one go. Breakup the print job in 3 parts and for each part manually enter the page numbers and then give the print command. Repeat this till the entire lot is over..........................sodeep
Apr 14, 2009 | Brother Office Equipment & Supplies
Can not delete document in print q - nothing else will print
Open task manager,(Ctrl +Alt +delete) and end task on print spooler,delete the file.print spooler will restart automatically.
This works best if you have the que window open first.
Please rate this fixya
Jan 25, 2009 | Lexmark X3550 All-In-One Printer
HP PSC 1410 All-In-One InkJet Printer Logo
173 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
