Noisy capstan which runs continously
Bought the deck used plays/ff/rew fine but as soon as you turn the power on the capstan? (spindle above the pinch wheel) spins continuosly even if the play button has not been pressed. It also makes a noise when turning but this resolves when playing a tape. Is this normal and if so what can I do to quiet the capstan.
  • 36 Answers
Most tape decks are designed so that the spindle will run when powered on. when you press play or record, the pinch roller elevates the tape to the spindle, tape starts to travel.
noise is basically from the mechanism, or deteriorated in time as yours is an used one. if you are lucky to find some good pinch roller rubbers of same diameter, replace them.
pc-cook
Posted on Jan 25, 2008
Works fine in FF and Rew but push play and the pinch roller closes and the tape moves to the heads but the
I do not know the model and many models have a different drive but from the first guess I would say the Capstan belt is either stretched, broken or liquified. You need a new belt.
I could be more helpful with a brand and model number.
May 26, 2015 | Audio Players & Recorders
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
A LOOP OF TAPE KEEPS GETTING PULLED OUT OF CASETTE WHEN YOU TRY TO PLAY IT.PLUS,IT SWITCHES BACKWARDS AND FORWARDS BETWEEN DECKS WHEN YOU PRESS THE PLAY BUTTON
FIRST TRY FAST FORWARD AND THEN REWIND. Allow it to ff and rew right to the end of the tape. on the tape. do this a couple of times. this may cure it as it sounds like the tapes are getting an imbalanced tension. If you still haver the problem, dip a cotton bud in alcohol and clean (carefully) the pinch wheel (the rubber bit that drives the tape through) and the capstan (the metal bit the rubber wheel presses against).
Oct 07, 2009 | Technics Audio Players & Recorders
AKAI GX-747 does not play or ff or rew. Capstan runs. Stuck in standby forward mode.
My name is Ed, I have the Akai GX-747 Reel to Reel, my problem is when press the play button it engages but the capstan does not spin up to the pinch roller. The reels do not turn.
My e-mail - edward_anderson@comcast.net
Jul 01, 2008 | Audio Players & Recorders
Kenwood Dual Cassette deck KX-97CW runs fast
Sometimes this is due to the tape not being pinched between the capstan and the rubber roller.
Make sure there is no slack in the tape when you put it in the deck. See if you can observe the tape going down over the capstan on the correct side.
If this isn't the problem, then the mechanism that engages the capstan roller may not to be working. In most cases, the rubber roller is mounted on the same mechanism that moves the record-play head against the tape. If this mechanism isn't moving, that would cause the problems you describe.
Jan 31, 2008 | Audio Players & Recorders
DC Motor turning continously in Cassette Deck
yes this is normal. the deck utilises what is called a rolling transport and the motor runs continiously to allow for mechanical cam engaged functions to work.
Dec 08, 2007 | Audio Players & Recorders
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
Apr 12, 2007 | Denon DRM-740 Single Dual Cassette Deck
166 people viewed this question
 Grubhead
Grubhead
