Question about Mitsubishi WD-62827 62" Television
Mitsubishi WD-62827 Problem
Mitsubishi WD-62827 DLP has a shadow that starts in the upper left corner running across the top of screen, at the right side it is approx. 3/4".
  • 1 more comment
  • webservice Feb 24, 2008
    Shadow across the top of the screen and light colors Blue, white, look "blocky" very low resolution. rest of the picture looks fine.
    I have purchased new lamp in anticipation of failure.
    will change soon and report
  • jgl frogg Dec 29, 2008
    i have pink horznital lines on screen ws-55905
  • Anonymous Mar 25, 2014
    about 3/4 of the screen is yellow. is this from a bad dlp chip or a bad lcd?
  • 579 Answers
Uh Oh! Unless this is something simple like a loose piece inside the projection chamber shadowing the screen it would have to be the light engine ($$$) warping due to overheating of its plastic housing. Check inside the cabinet for loose objects in front of the lens, then clean all the fan filters, then call your warranty company.
Hope Ya Fix It!
Posted on Jan 15, 2008
I have a mitsubishi wd-62827 tv. How do I access the bulb to replace it? Do I take the back of the tv off or the front?
on the back bottom right corner there are 2 Phillips screws holding a vent cover remove that, should have a small tunnel the lamp screws you can turn by hand pull handle to remove your lamp
Jul 03, 2011 | Mitsubishi WD-62827 62" Television
Mitsubishi & 1080p logo floating across screen
did you ever find the solution? Im having the same issue!
Dec 05, 2009 | Mitsubishi WD-60C9 60" DLP HDTV
There is a shadow in the upper left corner of the screen
someone is going to have to look inside by either removing the rear upper part of the set or removing the entire front screen---neither is easy to do. But considering your trouble I would not be surprised if the mirror is cracked---the entire front screens would have to be removed to replace the mirror--special mirror and special handling--I have seen several break when someone is not careful putting in.
Aug 22, 2009 | Televison & Video
Shadow across top of screen 1-2 inches thick
I have the same problem on my Mitsubishi set. Anyone have a solution for this problem yet?
Mar 13, 2009 | Mitsubishi WD-73927 73" HDTV
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Whites and Light Blues Very Pixely
If it's happening on all of your settings, It's probably going to be a problem with the DLP light engine. That TV came out in 2005, right? Did you buy it brand new, or as a floor model etc.? In any case, it's more than likely out of warranty and going to be a pain in the wallet. Best Advice I can give you with this info is hold out for some price cuts this holiday season. Sorry I couldn't be of help.
Nov 07, 2008 | Mitsubishi WD-62827 62" Television
Vertical line down the center of screen
A WD62827 is a V30+ chassis and is a DLP format projection screen Tv, not a flat screen, am I missing something?? For the symptoms you're describing with a WD62827 remove and reseat the DVI cable between the chassis and optical engine. If removing and reseating the DVI cable does not resolve the issue you may need to replace the Optical Engine part # 938P019020
BTW the current software version for this unit is 7.04.1F if you have anything less you might think about updating the software also..
Hope this helps!
Bill
Nov 29, 2007 | Mitsubishi WD-62827 62" Television
Mitsubishi WD-62827 62" Television Logo
464 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
