Question about Canon PIXMA iP1800 InkJet Photo Printer
Printer says it is jammed
Printer says that i need to remove the jammed paper and hit the reset button, but there is no paper in there to jam it
  • 5 more comments
  • SHANANA1 Apr 22, 2008
    same problem!!!!!!!!!!!!!
    i tried the unplug thing and it did nothing to change the problem
  • jcesc Apr 26, 2008
    when i try to print something appear a message "removed the jammed paper" and there are not any jammed paper. tell what i have to do...
  • Anonymous Apr 28, 2008
    resset drivers
  • coolose May 05, 2008
    mine's been like that for a month and i just bought it 1 week before the"paper jam"
  • Anonymous Jun 03, 2008
    same thing, can't get it to print. Says I have a paper jam and there isnt one
  • JPECAR Feb 04, 2009
    printer says paper jam and there is no jam
I solved the problem of constant Paper Jams by looking at the back of the Printer.
I found a slim pen has wedged in the Paper Feed tray.
Removing the Pen solved this Paper Jam problem.
These things happen , if you have Children with little fingers.
Posted on May 05, 2008
I have same problem, I've done all that, nothing changed
Posted on May 04, 2008
Unplug printer from wall for 12 secs and plug back in
Posted on Jan 15, 2008
I tried this and nothing changed
Posted on Apr 22, 2008
Paper got jammed. Removed. Still says paper jam, but I can't see any. What should I do next?
Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam,+but+there+is+not...
iFixitThere is no paper jammed anywhere! each time I would finish with the steps and ... I have to turn off and turn on the printer to get it going again. ... and the grinding sound and the paper jam message still comes up. i am going to try .... well no luck Iremoved ink and they are not dry - new- and now it says paper jam and not so ...
Fixing Brother Printer "Paper Jam" Error with No ... - YouTube
? 1:54
https://www.youtube.com/watch?v=SqWNFVIR6JA
May 30, 2014 - Uploaded by Refresh Cartridges
Fixing Brother Printer "Paper Jam" Error with No Paper Jammed.... problem occurred again. i try this many times but the problem is still in there. ... There was paper jam front rear on my brother j450dw that wasn't going away, that was ... How to remove jammed paper HP LaserJet Professional P1102 Printer ...
How to fix a printer paper jam. - Computer Hope
Dec 03, 2015 | Office Equipment & Supplies
Epson Photo RX510
Hi when you switch it on have you tried holding down the on off button for about 10 seconds as this often resets most printers.
Also when you sya thier is no paper jammed in printer are you absolutely sure their is not even i tiny bit of paper still stuck as it only takes a tiny bit of paper to make this message appear.
If you are confident in removing the paper feed witch is difficult to do as you need to make sure it goes back perfect as if it isnt the paper wont feed.
Alot of people say their is no paper jammedand they call somebody out to repair the printer and they get charged a fortune for removing a tiny bit of paper.
If holding the button down dont work then try switching the plug on whilst holding down the on off button let me know how you get on ok
Dec 10, 2007 | Epson RX620 All-In-One InkJet Photo...
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
When we hit the print button to print a page the paper will not feed into the body of the printer and the sign flashes for us to remove jammed paper and hit start button, when we do this it just keeps...
Paper jams
85% of paper jams are caused by worn rollers Chances are, when your tech arrives, he'll tell you that the jams were caused by worn feed rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
MP150 reset:
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
5110 ERROR ON PIXMA PRO 9000
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Solution: Removing paper jams MP800R / MP830 / MP530
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
  1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
  2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
  1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note: Be careful not to touch the components inside the printer.
  2. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  3. Load paper back into the ASF.
  4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
  3. Open the rear cover to check if the paper is jammed.
  4. Pull out the cassette and check if the paper is jammed inside the cassette area.
  5. Stand the printer with the rear side down, holding the document cover.
  6. Press the tabs together and pull the green cover toward you.
  7. Check if the paper is jammed.
    (If you were not doing Duplex printing, you do not have to follow this procedure.)
  8. Close the green cover and place the printer back to a normal position.
  9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  10. Load paper back into the ASF or cassette.
  11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Doc. feeder jam, after paper removed completely
HP LaserJet 3030 All-In-One Printer
Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
202 paper jam
I have this problem too, but the 2 sensors on the fuser are not stuck and seem ok to me. Any other suggestions?
Mar 06, 2009 | Lexmark T632 Laser Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
456 people viewed this question
old marine
old marine
