Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
No heat coming out
My Monitor is on but only thing is, there is no heat coming out of the monitor.
  • 625 Answers
Does your fan start? not the combustion fan, the other one?
Posted on Jan 19, 2008
6ya staff
SOURCE:
My sony monitor flat LCD HS74P went black and heated up
Its easy to repair. Some parts that needs replacement are the blown and bulge capacitor in the power supply section on the monitor. They are the very first to be affected when something goes wrong. The others where the inverter transformer and the inverter light. Very cheap to repair, the labor is the one that cost that much. Bring it to a nearer technician in your area and it will be repair in no time
Jul 09, 2010 | Sony Computers & Internet
Gateway Monitor FPD2485W
posibly a burnt out CCFL light , more likely an overloaded or burnt out CCFL power supply
JOAT
Oct 16, 2009 | Computers & Internet
Monitor clicks and then shrinks back and grows full by itself
It sounds like the monitor has a bad picture tube. As the thing heats up, one of the elements is sagging and touching another one. Don't even consider repairing this as it's completely uneconomical. A new 17-inch LCD monitor is well under $100 now, and any monitor repair (assuming you could even find a shop that works on them) would cost at least $50.
Jun 19, 2009 | Apple Computers & Internet
Dell monitor
Sounds like there is a heat related problem. Probably a bad solder joint somewhere. Could be hard to track and would probably cost you more money to repair and it does to purchase a replacement monitor. 17" LCDs go for around $150 these days.
Oct 28, 2008 | Dell Dimension 3000 PC Desktop
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
KDS Rad-9p wont stay on
my monitor will not work it will come on when the pc is cut on but it will not display
Aug 24, 2008 | KDS Radius RAD-9p 19" Flat Panel LCD...
Iiyama vision master pro 450. Faulty auto switching??
hi,the problem is with the LCD electronics , you will need to get it repaired from the sevice center, when u power up the LCD its heating up something inside which is switching it off .
Dec 22, 2007 | iiyama AX3815U 15" LCD Monitor
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
119 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Thomas F. Schneider
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
