Question about Pelonis HF-0019 OSCILLATING HEATER - OFF WHITE
"FF??? on display thermostat
Pelonis Model HF-0019 Fan Forced Heater with Electronic Thermostat Control. When I turn it on, it displays 99' F when I try to adjust the temperature setting, or push any buttons for that matter, it displays "FF"???
  • 12 Answers
SOURCE: Unit won't turn off - it's a Pelonis HF-0034
Sounds like a faulty thermostat switch.
Posted on Dec 16, 2008
SOURCE: Pelonis HF-0034 turned off 10 sec after starting; won't restart
We had one of these heaters also. Used for one year for short periods of time to heat an extra room. Went to plug in and nothing. My husband took the bottom plate off to see if there was a blown fuse and instead found a burnt wire, which had melted part of the plastic disk. If I were you, I would throw it away and get something else. This model is discontinued and I am sure for many reasons. I would look for a different manufacture also. I called customer service and after being told to bad, the man hung up on me. Great customer service. :(
Posted on Feb 05, 2009
  • 11896 Answers
You can find your manual here:
And for electric type you can get it here:
Posted on May 15, 2009
  • 4 Answers
I've been through 4 or 5 of these (and similar models) with the same problem after anywhere from 3 months to 1 year of use. It appears to be an overheat condition. Unplugging for about 10 minutes resets the overheat protector, but it will overheat again after running a short time.
Sometimes you can extend the life by blowing out the heater with compressed air, especially around the electronics at the very top and the contact points at the top of the circular heating element.
I'm currently trying a Lasko 755320 from -- cheaper, more features, better user interface, more heat, and it almost has to be more reliable than the pelonis.
Posted on Nov 28, 2009
SOURCE: i need a switch for my heater,how do i order the go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
Posted on Jan 08, 2011
Purpose of left button
Hi Harvey,
Left button of what tool?
Sep 28, 2016 | Pelonis Heater. 1,500-Watt Digital Fan...
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
HF-0020T Fan Forced heater
If the symptoms are as described, the heater probably has failed completely.
Nov 01, 2012 | Pelonis Heating & Cooling
I own a Kennmore Elite refrid. The screne at the ice maker says: Er FF Sears cannot help. Can you tell me what this means and how to fix it? Phone is 907-304-3480. Name is Harvey live in remote Nome...
Error Freezer Fan." Once the evaporator fan stops turning for more than 115 seconds, this error message will be displayed.The best fix so far is to replace your defrost thermostat with a Whirlpool Refrigerator Defrost Thermostat 4387490. This will allow your defrost heater to more thoroughly defrost your coils. The one you have stops the heater prematurely causing a short and nearly useless defrost cycle.
Mar 10, 2010 | Refrigerators
Penguin model 610012-001a/c compressor won't start
I would check to make sure that the control is sending the "cool" signal to the control unit. LO on the room temp display usually means that the fan speed is set to low. Is LO and Auto showing on the display at the same time. Try resetting the thermostat first. Hold down the Mode and Zone buttons with the tstat off. While holding them down, turn the tstat back on and hold the buttons down until FF appears on the screen. Release the buttons and try the AC.
If this does not work, on the control board is a freeze control switch plug (blue usually). Try unplugging this unit and insert a small jumper wire. If the Compressor comes on and runs then you have a bad freeze control switch. If not, then you should replace the control board.
Hope this helps,
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
43 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
