This problem should be removed because:
Problem with KitchenAid (32685) Mixer
will not turn on
Solutions (1)
Best Solution
This can be caused by a number of things. The first thing to check will be the carbon brushes located on the left and right sides of the unit. Just simply unscrew the caps with a straight screwdriver. Once removed your can clearly see the shape of the carbon brushes. If they appear to have little or no wear and aren't broken, this won't be the cause of this problem. Also take note when you take them out AND put them back in as they willl only fit ONE way. The next thing to check will be the main control at the rear of the unit. After removing the power source, you can also remove the rear access panel. A phillips screwdriver is required. Next after removing the panel, you can now see the main board. Inspect it for any immediate signs of broken or burned wires also check the bi-metal on the control itself, as this will often indicate a faulty board. If however, everything looks good visibly and you still have no power to the unit, the last possible solution could be that the power cord itself has an internal problem. Hope this helps
Thanks
Sunbeam hand mixer. One beater not working
My Sunbeam 2485 has a great moter but one of the beaters does not turn. I had taken the mixer apart and discovered a small metal spring pin...
H-600 Turn Handle slips, bowl does not go back...
Turned the handle like always and now the bowl does not go back down, handle turns with some noise
blade is hitting the bowl and the screw will not...
I tried to adjust the screw so the blade would not hit the bowl, but it will not turn to the left any further. Does ant one know what is...
Turntable does not turn. Motor runs. Beaters...
Sunbeam Mixmaster Mixer on stand - purchased in 1977. Service # 1-7A. 225 watts, 120 volts. 12 speeds. Listed Mixer 423A. -- The turntable...
blade will not turn
power switch turns on motor but blade will not turn
Add Your Solution
our kitchen Aid mixer sparks and smells burning...
My kitchen Aid mixer sparks when turned on the power button and looks like it is going to catch fire
beater issue
after years of use the beater will not twist on to attach
My KitchenAid Mixer has worked fine for a few...
It may be due to my daughter using it without locking it.
Related Topics
Fix-O-Meter
3,855
3,855 people viewed this problem
- 10 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top KitchenAid Mixer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
