Question about Apple iPod nano
Ipod nano 2gb hums, not working
Hums when plugged in with USB to either outlet or computer, no functions at all. No function when not plugged in to USB and No hum either. Battery replaced and worked x 1 day, now back to same problem.
    President:
  • 4,402 Answers
I have almost fixed it but its not completely gone. go to itunes (7.0.2) click on the "Help" tab then click on the "check for updates" tab. download firmwire 1.1.1 onto your iPod nano and for some people it took the very irratating noise away and for others, like myslef, lowered the noise so i can only hear it about 1/2 an inch away
Posted on Jan 15, 2008
Unlock
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
Jul 24, 2013 | Apple iPod nano
DESBLOQUEAR PANTALLA
How to Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Things You'll Need:
iPod Nano Mac or PC computer iPod USB cable
1 Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
Jan 05, 2012 | Apple iPod nano
Enter code i pod \
Hi
Things You'll Need
Dec 30, 2011 | Apple iPod nano
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Feb 22, 2011 | Apple iPod nano
How to charge it.
You need a nano USB charger cable to connect the nano to your computer or an AC adapter USB nano cable to plug the nano into an AC outlet. You can find a variety of cables and adapters on the internet that will allow you to charge your nano.
Please rate this solution. Thanks.
May 10, 2010 | Apple iPod nano
I have an ipod Nano 2gb. It works great when it
you connected ipod with some high energy source or tried to provide a high energy from it e.g you connnected it with speakers,or head phones other than ipod. ipod works fine when attached to computer because it acts as an usb device at that time. go to Ipod shop and replace a chip inside it which is blown
Mar 02, 2010 | Apple iPod nano
I pod nano not reconized by laptop with vista usb device not reconized code 10 appears
Which USB ports are you using? I just had this issue on a customer's computer and it turns out that a 5 port USB 2.0 hub they had installed in the pc wasn't functioning properly and so I would get a code 10 on their iPod nano. I plugged it into the onboard USB 1.0 ports and it installed correctly and synched. I would suggest trying other USB ports. If that doesn't work then go to Programs and Features in Control Panel and uninstall all apple products and then reboot and reinstall iTunes.
Oct 15, 2009 | Apple iPod nano 4th Generation
2GB nano wont charge
Check this first. Both computers have USB2. Both computers are awake. iPods will not charge from USB1 or when the computer is asleep. Check the computers and cord is ok by plugging in another iPod. If the iPod is still under warranty, Apple will replace it.
Apr 29, 2009 | Apple iPod nano
Ipod nano 4G silver not syncing
install the version 7.7.20.14 it may work
Jan 09, 2009 | Apple iPod nano
Apple ipod
I have a 2GB Apple ipod (white). I can listen and do all functions but the ipod wont turn off at all. I charge it thru laptop. Can you help please
Aug 08, 2008 | Apple iPod nano
Apple iPod nano Logo
47 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
