Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Can't close the door and finish the wash..
I opened the door during a cycle, now I can't close the door. The cycle still runs with door open. However I can cancel the cycle The display is not fuctioning either, now. I have a Bosch SHX36L Any ideas? I
I had the exact same problem, which I solved with the same solution suggested by tbdkmh. The latch had flipped shut while the door was open and just needed to be reset. I had to disassemble my door too, but I keep thinking that there has to be an easier way, once you know what needs to be done.
Posted on Apr 14, 2008
I broke down and called a repair man. He seem to think the problems was related to the unit being off level. My house is 105 years old, it's pier and beam on clay. It's like a house boat on the water. The house is constantly doing the wave. It's tuff to live with.... So now, this is another object I've got to keep my eye on and keep level. Hope this helps someone out there...
Posted on Feb 10, 2008
I'm not familiar with your model but I have a SHY66C and did the same thing. I had to open the door and remove the screws around the perimeter and take off the door skin. I then removed the screws holding the top plastic cover and took it off. You can then pry out on the metal tabs holding the hard plastic door latch and pull down on it to remove. There is a spring loaded leg on the outside that will be pointing toward you if it were in the installed postion and you are facing the door. Push in hard on the middle part of this leg until it clicks and resets the latch. Of course then just reinstall the door in reverse order. Remember that you have to put the plastic cover back on the top before putting the door skin back on.
Posted on Feb 01, 2008
I have a Hormann 5500 series. The door closes but automatically reopens when it touches the ground.
I do not know, but I guess that a "bad" handling of the machine during a move may have maligned parts.
This is only a guess.
Jun 28, 2017 | Washing Machines
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Sigla f26 sulla lavatrice
F26 DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds. Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Oct 22, 2014 | Washing Machines
Whirlpool aquasteam 6 sense model number 859297015700 error code f26
DOOR SWITCH ERROR
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
-Door switch open while door is locked.
Thanks for using FixYa
Mar 04, 2011 | Whirlpool Washing Machines
What does f26 mean
DOOR SWITCH ERROR
Thanks for using FixYa&^%$
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Keeps flashing f26 fault
DOOR SWITCH ERROR
5 seconds.
Dec 24, 2010 | Whirlpool Washing Machines
What is f26
DOOR SWITCH ERROR
Thanks for using FixYa$%^
Dec 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error f26
DOOR SWITCH ERROR
Thanks for using FixYa $%^&
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-26 flashing
DOOR SWITCH ERROR
5 seconds.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
257 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
