Question about Car Audio & Video
Mustang twin turbos
I have a mustang with twin t3 t4 turbos and i need
a diagram for hooking up the waste gates and the blow off valve
also i want to put a boost controleron it
  • 631 Answers
This is posted in the car amplifier section and probably won't get answered. Try posting it in the appropriate category and someone should be able to help.
Posted on Jan 15, 2008
I need ang diagram for hobart mixer 9 out wire T1/T2/T3 AND T4/T5/T6, T7/T8/T9 which is the right partner of t1/t2/t3???
Having 9 wires means it is a 3 phase motor.
For 220 to 240 Volts - L1, T1 and T7 go together. L2, T2 and T8 go together. L3, T3 and T9 go together. T4, T5 and T6 go together.
For 440 to 480 Volts - L1 and T1 go together. L2 and T2 go together. L3 and T3 go together. T4 and T7 go together. T5 and T8 go together. T6 and T9 go together.
Apr 12, 2015 | Hobart Food Mixers
I bought a T/3 T4 T3 turbo charger 2.25" 4 bolt exhaust .48at turbo Charger 42ar oil cooled only for an 04 maxima and I'm wondering what accessories am I gonna need piping and intercooler wise and turbo...
Turbo manifold, blow off valve, waste gate, intercooler, turbo timer, piggyback or standalone ECU, most likely an all new exhaust system, new intake, filter. An oil cooler may be needed, as those turbo chargers are most likely cooled and lubricated by the oil in the engine, needing to be piped through the turbo itself.
Jan 11, 2018 | 2004 Nissan Maxima
On my 2000 Golf 1.9 tdi ALL vacuum hoses are disconnected. How do i connect the hoses between the turo boost control valve and the egr solenoid valve as well as the main vacuum hose from the vacuum pump. I...
You will need a Vacuum hose diagram to hook thes up correctly. There should be a diagram on the hood or raiator cover of the vehicle. If the diagram is missing you will have to take ALL info from your car (Year,Make, Model, Engine size, Engine code) and obtain the diagram from a dealer.
Jul 28, 2011 | Volkswagen Golf Cars & Trucks
Subaru impreza turbo intercooler drives like normal 2l but has no boost?
I would start looking at your boost control valve and vacuum lines going to your turbos waste gate, as well as the recirc/bypass valve. Usually when cars don't boost they have either stuck open waste gates or recirc valves. Or something is blocking the boost control valve from releasing the waste gate. Also make sure that all your intake hose clamps are tight so they are not releasing boost prematurely.
Jul 26, 2011 | Subaru Impreza Cars & Trucks
What parts do i need to turbocharge a 93 subaru impreza 1.8L
T3/T4 Turbo
Lubrication Kit "oil pump and lines"
Turbo Bracket
Intercooler Brackets
Aluminum Intercooler Piping
Silicone Couplings
T-bolt Clamps
Type RS Blow-off Valve
Stainless Steel Headers
Stainless Steel Downpipe
Rising Rate Fuel Pressure Regulator
Auto-meter Boost Gauge
Vacuum Harnesses
Cone Style Air Filter
PVC Filter
And to be able to Dyno Tune the engine for the extra boost. Nothing more then 8 PSI with out replacing the Pistons.
Might of forgot something but this are the major things needed.
Dec 10, 2009 | 1995 Subaru Impreza
I have an external wastegate with a 7psi spring and a blow off valve on my 96 turbo gsr and it still goes up to over 20psi how do i stop the boost getting so high. also it is a brand new top of the line...
The waste gate valve is there to dump the "extra" boost air direct to the engine thus bipassing the turbo. Remove and clean the gate valve; In all likelyhood is is stuck open.
Dec 08, 2009 | 2002 Mitsubishi Lancer
Need wiring diagram for 3 phase electric motor
motor leads on a three phase are T1, T2, T3, T4, T5, T6, T7, T8, T9. for high voltage [480] L1 to T1, L2 to T2, L3 to T3, connect together and tape - T4-T7, T5-T8, T6-T9. For LOW voltage [240] L1 to T1 & T7 & tape, L2 to T2-T8 & tape, L3 to T3 & T9 & tape. T4-T5-T6 together and tape.
Oct 20, 2009 | Saws
I need of a turbo waste gate on a 7.3 liter
Yes it will hurt the performance if yo do anything wire the waste gate shut. however the waste gate is on the inside of the turbo unless you have a special turbo that is not stock.
Sep 30, 2009 | 1997 Ford F250 SuperCab
Car Audio & Video Logo
159 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
