This problem should be removed because:
Problem with Toshiba 32A33 32" TV
power will not come on
Solutions (1)
If you can see inside your tv..check the fuse. If the fuse is good, you have bad grounds on the solders and certainly som bad capacitors..I always look for caps that have 160volt to 250volts with less than 10Mfs. These almost always are the culprit. And Maybe check the main filtercap..About 200volts and 470Mf. They sometimes go weak. [Just sometimes] If the fuse is bad you have a bigger problem...This will include a bad H.O.T. and maybe a resistor or diode as well! Also a replace the horizontal driver transistor! Oh yes even the contoller Ic could go down....I would guess the first part of this solution is the answer and you have a good fuse!
lcd screen does not stay on.
The power button on the top of my Sharp lc32p70e 32" Lcd screen does not stay on. If depressed I get a picture, as soon as I let go it...
looking for a power supply
I found this TV for sale without a power supply at a discount store. This is for a kids bedroom and it was quite a deal. I am looking for a...
Sony KV-32S45 32" TV no power
no power
I have GE model 27GT618 made 1996. No power to
I have GE model 27GT618 made 1996. No power to TV. Have switch outlets, jiggled cord, nothing. Tried power from the TV as well as remote but...
SAMSUNG T.V MODEL; CS-29Z40HE
SAMSUNG T.V MODEL; CS-29Z40HE This T.V buy on JULY 2007 PROBLEM; No power; total dead; no red led stby; have beep sound...tick...tick...like...
Add Your Solution
Toshiba 32A33 32
remote wont work or nether dose the buttons on the tv too
i need the block that the antenna coax hooks to
someone pulled the coax without unhooking it
menu bar pops up automatically and goes through
menu bar pops up automatically and goes through the whole menu non stop
32a33 only have half a screen of white raster
32a33 only have half a screen of white raster lines? what do i need to check?
Fix-O-Meter
54
54 people viewed this problem
- 0 people are following this problem. Be the first!
Top Toshiba Standard Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
