Question about Whirlpool GS6SHEXNL Side by Side Refrigerator
Whirlpool side by side GS6SHEXNQ00
The frame around the freezer section is hot to the touch. The inside is cold. When you open the doors the center section that the seal goes agaist is very warm/hot. Could the defrost cycle be stuck on?
I unplugged for 5 minutes and the compressor started up and the blowers are on.
Any help? Is there a reset for this?
  • Trezhur May 12, 2008
    My Model # is ED5FHEXNS01. The area that divides the freezer from the refrigerator gets very hot to the touch but cools down for a little while and then gets hot again. Ice cream is melting. No ice.
  • donaldandshe Jul 06, 2008
    The insulation strip around the doors is hot to the touch. Everything else is fine, except ice cream is soft. This happened after regrigerator was moved to house with old wiring.
    Scholar:
  • 27 Answers
Hi. You either have a dust blocked condenser coil or your condenser fan motor has stopped. It is located next to the compressor. If the motor has failed, put a fan in the back of your refrigerator and let it blow into the back of the refrigerator until you get a fan motor. Make sure you leave the compartment cover off the back of your refrigerator. Your compressor is super hot now and the start device relay is getting hot and may fail if the situation isn't resolved soon. I would get a new start device relay for the compressor also to prevent future failure. The reason for the hot areas is because the freon is not being cooled and there is freon tubing located inside the cabinet where you are touching. Please check my items on Ebay as username themackshack. Good Luck, Mack
Posted on Feb 02, 2008
6ya staff
SOURCE:
Seals on my beco are hot to touch fridge freezer feel warm
Almost the same post as my last. This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | Refrigerators
Frezzer keeps icein over
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check:
1.) Door Gasket -Take a piece of paper. With the freezer door closed run the paper around the gasket. If you can do that, then you are not getting a good seal.
Repair: Clean the freezer door gasket with soap and water. While still wet, take a hair dryer and a spatula, going around the gasket, heat the gasket while pulling the gasket out to expand it.
Note: This only solves the problem if there is frost in the front area of your freezer.
2.) Freezer fan not working - In some cases, The freezer fan helps to prevent warm air from getting into the freezer.
3.) Food Storage - Make sure you do not overload the freezer, and that the food product is inside the bounds of the racks.
4.) Fresh Food Section Air Vent Wide Open - This is your probable cause: Heat goes to Cold like a magnet. When you open your fresh food section door and then close it you are forcing warm air up the vent that goes to the freezer. You probably have a broken air vent assembly.
Oct 08, 2014 | General Electric Top Freezer 21.0 Cubic...
Refrigerator not cold
You say refrigerator SIDE not cold? You would expect the outside panels of a refrigerator to be around room temperature or warmer as the fridge removes heat from inside the cabinet and expels it outside. If you mean the inside of the fridge is not cold then check the door seals are sealing correctly around the door frame. You could also check that there is nothing inside the fridge protruding and therefore inhibiting the closure of the door correctly.
Jan 04, 2014 | GE 20 CFT GSE20JEWF BB BLACK COLOR SIDE BY...
I have a Fisher Paykel E388 upright freezer which freezes in the bottom couple of drawers but not toward the top. The motor is running and fan spins when you open freezer but stops when door is opened. Any...
Cold air always settles on the bottom Check the door seals above the cold area . Check for broken seals ,cracked seals and seals that are not touching the frame. Place a thin piece of paper between the seal and the frame and close the door . If the paper falls or is easy to pull out that may be your problem. Test at various points around the door.
Apr 06, 2013 | Refrigerators
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Feb 13, 2010 | Frigidaire 19.53 cu. ft. Commercial...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
GC5SHEXNQ02 Whirlpool 2door ref - Panel gets hot
I am not going to say the problem is normal. Normal operation those strips are placed behind the metal and inside the walls around the door seals to prevent moisture or sweating around the doors. They are usually noticed to become hot when there is a change in the control boards operation. Some brands have the hot gas from the condenser circulating around the doors. If your model has an economy switch, switch it on. I would look for any abnormal operation of the refrigerator like compressor or condenser fan stopping or ice buildup or abnormal temperatures in the fresh food compartment. If this continues I would unplug the refrigerator and open the control panel inside the fresh food section and examine both sides of the control board for signs of heat or burn marks on both sides. May not be anything to be concerned about also because this may be the first time you noticed this. But it should not be too hot to touch. Sea Breeze
Jun 23, 2009 | Refrigerators
Freezer works, refrigerator does not cool
Often the cooling section is located in the freezer and their is a hidden fan that blows the cold air into the lower section. If the fan quits working the refrigiator section wil not be cool.
Jun 19, 2009 | Refrigerators
Outside of refrigerator is hot - almost burning hot
The frame between the doors has a refrigerant line running through it to prevent moisture build up between doors (should be room temp. or slightly warm, not hot).
If that area between the doors is hot to the touch, you have two things to check: 1 - are the condenser coils under unit or in the back clean? 2 - is the condenser fan running in the back that is near the compressor running?
Aug 24, 2008 | KitchenAid KSCS25IN Side by Side...
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool GS6SHEXNL Side by Side Refrigerator Logo
487 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
