You must turn it counter clockwise.If there isn't any of the cross left you have two options you can take a small hack saw and cut 3 or 4 slits in the drain lip, being careful not to scratch the tub. Then pry the lip up very carfully with a small flat screw driver & pliers.You should be able to unscrew it now.Or if you have access to the waste and overflow, behind the front of the tub you can remove the overflow, (its the piping with the cover plate at the top of the tub) and move the waste shoe from side to side,to loosen the drain up. [thats the part the drain screws into] I would try my 1st solution.You would most likely have to replace the waste & overflow and maybe the trap with the 2nd. Good Luck.
