Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Kenmore Progressive Bagless vacuum cleaner
When im vacuuming no dirt is going into the bagless container and dust is flying everwhere. I am not sure where the dirt is going but we just bought it Nov 26, 2007. has there been any problems with this brand before.
  • tay tay 32 Jan 15, 2008
    I am no able to see if there is a clog anywhere buy the way it is built
    President:
  • 1,673 Answers
Check down by the brush roll to see if the inlet is clogged. This type of problem usually means there is a clog. But you do have a year's warr. on this, if you can't figure it out, then take it a Sears repair shop.
Posted on Jan 15, 2008
6ya staff
SOURCE:
Which vacuum would you prefer for pet hairs ?
I've been repairing vacuums over 30 years, I prefer a bag vacuum because a good bag vacuum is a lot less maintenance, all the nasty stuff goes in a cheap paper bag (which is actually just a really good great big cheap filter) which you simply remove and gently sit in the trash. It usually takes less than 30 seconds to change bags and only needs done about once a month. You will dump a dirt cup about 40 times compared to changing one bag. Bags compact the dirt while bagless fluffs the dirt. Bagless filters and dust compartments need frequent cleaning and replaced at least once a year to work properly. Bagless vacuums leak more dust and dirt which you will notice on your vacuum. In the long run its much easier and cleaner using a bag vacuum plus they usually last much longer, usually outlasting 3 or 4 bagless vacuums. Much less expense and hassle in the long run.
Mar 05, 2018 | Vacuums
Got a dirt devil upright I've cleaned out the Short hose extension hose also cleaned under bottom plate checked belt looks good don't see no holes or cuts in hoses no cracks in bagless container
Hello, Im assuming that your unit has no suction. If this is the case, it is still plugged. Run a stiff wire through all the hoses, starting at the on behind the bristle brush. Make sure all the bagless filters are completely cleaned.
Mar 30, 2017 | Dirt Devil Vacuums
Throws dust all over. Missing hepa filter. Is that the problem?
Of course. The filter is there for a reason and it also maintains pressure. But also make sure that the seals to the container are good and that it is located correctly.
Apr 23, 2016 | Dirt Devil Ultra Vision Turbo Bagless...
Why is my Dirt Devil Vacuum Hose lacking suction?
I have a Dyson and was having a similar problem some time back. I found out these bagless systems still have a filter that picks up the fine dust to keep it contained. Find out where yours is located and beat the dust out of it really good or just replace it.
Hope this helps.
Mar 10, 2014 | Dirt Devil Vacuums
When you remove the hose to use the utensils, the dirt is flying out of the hose at the bottom where the utensil is removed from
Hi Karen. I understand how frustrating this can be. Dust blowing from the bottom hose is normal because the brush is still rotating. If there's excessive dirt flying out, then you may have a clog in the bottom hose.
Here's a quick link to check for clogs: http://www.bissell.com/FAQDetail.aspx?id=1419&cid=ccsocial
Apr 20, 2013 | Bissell 6591 Power Trak Revolution Bagless...
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
I just bought a foldaway hoover with wide path. I plugged it in and started to vacuum and dust flew everywhere. Walmart would not give me my money back so they gave me another hoover foldaway with the wide...
Take to Walmart, plug it in and start to vacuum THEIR floors!
Try removing the dust container and look for anything blocking airflow including the HEPA filter. Make sure the dust cup has a seal where it joins the vacuum. The fix is probably simple, but it shouldn't be up to you to do so!
Nov 16, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Bissell powerforce bagless vacuum,when turned on dust flies out sweeper
Dust flying out of the sweeper indicates that their is a blockage in the pathway that the dirt normally travels to get into the dirt collection chamber. Turn the sweeper upside down and look for a blockage of some kind. Also, empty out the canister and look to see that the pathway into the canister is clear.
May 18, 2009 | Vacuums
Upper Filter gets clogged quickly
You may have to replace the filters, air maybe restricted going thru them. The main filter is part #73494, and the foam #74038. Also make sure the SLINGER/CYCLONE ASSY part #74068 isn't clogged up.
Jun 10, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
141 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
jdthefixer
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
