Question about HP Pavillion ZV6000 Notebook
HP Pavillion ZV6000 AC Adapter
Ok when my charger is in it will charge only if my computer is off and the moment i turn on the computer everything starts blinking, how can i fix this and get my charger to work when my computer is on?
    Problem Solver:
  • 7 Answers
There is battery problem dear so replace your battery u will get result..
Posted on Jan 15, 2008
Zv6000 will not charge will not run off of cord
Try another Cord/Charger with the EXACT same power specs. Has the AC jack been damaged due to pulling on the cord while plugged in?
Apr 13, 2013 | HP Pavillion ZV6000 Notebook
I have a gateway laptop & it wont turn on. its charge & everything.
Hi! Welcome to www.fixya.com.
Its definitely a hardware issue. You can remove the battery and ac adapter and drain the power for 10 seconds. then use only the ac adapter. Press the power button and if it did'nt turn on. You have to call your manufacturer for motherboard replacement.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | HP Pavillion ZV6000 Notebook
I have a HP 6735s Laptop. I have been getting a few of the "Smart AC Power Output" messages, however yesterday after I turned my laptop off and then on again, the laptop wouldn't detect the AC...
bad battery,
you do know that the main batteries are "love to fail"
right,
just about all batteries do that in everything,
even the coin cell,inside can fail in 5years flat.
if power pack is 19vdc with volt meter, good !
the battery is next, yes it runs pc but can be bad.
a bad battery can still have power but overloads the charger chip
it really is an analog world. (reality)
if savvy , always keep a spare battery for moments like this.
Apr 07, 2017 | HP Compaq 6735s Notebook
Power suppy ok but computer won't turn on
Try doing a power reset. Remove battery and power adapter, wait for 10-20 seconds then put the battery and adapter back in then turn the computer on. You can also try to remove the battery and just plug it in on the power outlet.
Jun 24, 2010 | HP Pavillion ZV6000 Notebook
I have a problem with the charging bias software. The power button light starts to flash and charging stops. I have to disconnect the mains power, wait until the pb light stops flashing and then power up...
I had this with a laptop recently. It could be one of three things, the first is the charger, which was my problem. The second is the battery. The third is the charging circuit which is also the most expensive to repair.
Please take a moment to rate my solution.
Thanks.
Simon.
Rytech Computer Services Limited
Dec 01, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
HP Pavillion ZV6000 - Charging Problems
hi
It seems that your laptop is not charging so in that case you must take your laptop to your vendor.For more support you can visit---------http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
Jun 22, 2009 | HP Pavillion ZV6000 Notebook
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Ac cord
And the problem is??
If nothing else, go to ebay. cheap prices, plenty to choose from.
If money doesn't matter and you're in a hurry, purchase a high quality "universal" power adapter, such as ICE. Make sure it carries 90 watts and can handle the appropriate amperage.
Good luck
Feb 08, 2008 | HP Pavillion ZV6000 Notebook
Charging issues
if you can get a hold of a 12 volt cigarrette lighter car power cord, try and see if the lapper starts then,
if it does, then the power adapter maybe bad
Feb 02, 2008 | HP Pavillion ZV6000 Notebook
HP Pavillion ZV6000 Notebook Logo
100 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
