Question about Nikon Speedlight SB-800 TTL Flash
Sb800 doesn't flash
No matter if I push the flash button or take a picture all that happens is the ready lights flashes on the sb800 and no flash.  Help if you want me to reset the flash or camera please explain what and where the buttons are. THANK YOU.
  • 2 more comments
  • Anonymous Apr 22, 2008
    sb-800 does not flash when ready light is on have checked the on/off mode
    I did hear a cracking sound maybe new flash tube?
  • allistewart May 16, 2008
    I've never used my flash. We tested it a few times when we first got it and now I've got a job next week and I took it out to try it out and get comfy with it and it won't fire at all. I've checked and triple cked the settings and nothing. As much money as we've put into it it would work more than 3 times.
  • Anonymous Oct 02, 2008
    I have 3 SB800's at this time. None of them work.
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Have you contacted Nikon or a repair person in your area about this problem? This may be a common problem and require parts rather than resetting anything (of which there are none that I know of)
  • 216 Answers
Let's force the flash to fire:
nstalls four fresh batteries.
Turn on flash, do not connect to camera
Wait until flash is ready
Get a small wire with insulation and strip both ends about 1/8".
With one end of the bare wire lead, touch/hold CENTER TIP
Contact(silver pin from flash).
Make sure flash head is not pointing at your face.
With other end touch bare wire to OUTSIDE Contact (silver on
outside of hot shoe that rides into camera hot shoe rails-this is ground).
Flash should fires, gets a flash out of the flash tube.
If not, you have flash problems.
You most likely hurt the flash by using the dome filter on top of flash.
Over 80% photographers are doing this way when shooting flash photography. And 95% for wedding photographers.
This will shorten the life of the flash.
Even more with that adapter parked onto the flash.
Hope they are helpful to all photographers.
Suggestions or comments,
Posted on Jan 15, 2008
I have been through multiple upon multiple main circuit boards
same thing happens and i do use the dome filter
Posted on Sep 15, 2008
When I turn on the coffee machine flashing red button calcing. and 'put in a container for water descaling solution., when I hold the button for more than 5 seconds nothing happens.
push it for 5 second and if its still flashing doesn't matter turn the steam knob anti-clockwise end let the machine do to the descaling cyrcle, when then water tank emptied the rest of buttons starts to flashing, turn the knob off and your machine is ready!!
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
How do i change from remote ttl on my nikon sb800.
Press the Menu button. Scroll to the Custom Setting Menu. Scroll to "e Bracketing/flash". Right arrow and scroll down to "e3 Flash cntrl for built-in flash" and push the center button. You now have access to the TTL, Manual, Repeating flash and Commander modes. Right arrow on CMD and a menu will appear that allows you to set up the built in flash and the external flash groups.
Aug 15, 2013 | Nikon Speedlight SB-800 TTL Flash
Sb800 is on mode lcd panel showing all ok buti pres flshfire flash not fire
What's "flishfire"?
Try this:
Remove flash from camera.
Turn on flash
Wait until ready.
Short out center pin to outside contact, this should fire the flash.
Jan 14, 2010 | Nikon Speedlight SB-800 TTL Flash
Nikon SB 800 fires but pictures reamain dark
I have 2 SB-800s. When batteries leaked in one Nikon took forever to fix it, so they eventually sent me a refurb. Then they sent my original back. Which was great, until recently it developed this problem.
Another possibly related side effect is the modeling flash does not burst -- it only fires a single (very bright) flash.
The capacitor argument sounds likely. Coincidentally I also had a problem where the flash would fire sporadically -- but that was due to scuz buildup on the contacts.
Sorry I don't have a real solution for you.
May 27, 2009 | Nikon Speedlight SB-800 TTL Flash
Flash doesn't fire
Should fire from test button. If not flash tube is blown.
Jul 08, 2017 | Digital Concepts 952AF for Pentax Flash
Nikon sb800 speedlight
The trigger circuit and flash tube needs to be replaced . If you want me to repair this contact .
Berrie Smith Camera Repair
Mar 27, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb600 doesn't fire well off the sb800
The sb600 needs to be able to see the preflashes of the sb800, so this is probably caused by one of two things.  The first thing I'd check is whether or not the light sensor on the side of the sb600 was covered, blocked, or facing away from the sb800.  I've had problems outdoors when I forgot to have the light sensor face the camera.
If the sensor was facing the camera, it is possible that the flashes didn't have a good line of sight to each other.  That normally shouldn't matter, but if there is a high ceiling and lots of people, it could be the case.  I don't know if it will help, but in any case I would recommend using a StoFen Omnibounce on the sb800 to increase the likelihood that the light finds a direction where a surface to bounce off of is found.
Good luck.
Feb 02, 2008 | Nikon Speedlight SB-600 TTL Flash
Flash doesn't flash
I think you've posted this problem already.
Anyway please see Jan 15, 2008 SB800 doesn't flash.
Check that first.
Jan 15, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb800 will not flash
To reset the device, hold down the "MODE" and "ON/OFF" buttons at the same time for about 3 seconds.
Hopefully that will do the trick. if not you cant contact me for further help!
SB800 firing but not syncing??
I had that same problem with the SB600 and the SB 800. Solutions; get a new one. After about a year of usage the sb600 started giving me that problem. It flashes but it does not sync. It still works as a remote unit, but not mounted on the camera. The SB800 just went to a coma last weekend. No sync at all, not even as remote unit, no strobe function, just a bright flash, when triggering the test button with new fresh batteries, it flashes at max power once and takes around 7 seconds to recycle. No multiple flashes at all. I had to buy a new one.
Jan 09, 2007 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
796 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
