Question about Nokia 6288 Cellular Phone
Change of front casing
I wanted to clean up my unit. the only way, i know to do it is to remove and/or replace its front casing. how will i do it?
    Guru:
  • 167 Answers
When dismantling any phone, great care should be taken to ensure that no damage is caused to any of the parts. Rough handling may result in severe damage of many parts, and if proper anti-static procedures are not followed, electrostatic damage may result in any electronic component.
Before commencing, it is recommended that the correct tools are purchased for the job in hand - at the very least, you will require a Torx T6 screwdriver.
Step 1. Release the battery cover.
Step 2. Remove the battery cover and the battery.
436c23c.jpg Step 5. Using a thin plastic shim, release the two clips
at the top of the phone.
Step 6. Now slide your shim along the sides of the A cover to release all the remaining clips.
Step 7. Now lift up the A cover.
Step 8. Use your shim to release the keypad.
Step 10. Carefully lift the PWB unit - bear in mind that this is glued in place.
Step 11. Remove the PWB unit and screen.
Step 12. Release the flex at one side,
Step 13. and then at the opposite side.
Step 14. Now lift away the PWB assembly.
Step 15. Release the LCD connector.
Step 16. Separate the screen from the metal shield.
Step 17. Release the camera guide assembly.
Step 18. To remove the camera you should use a specific tool which is not publicly available. This step is included here purely for the sake of completeness.
Step 19. If you have removed the camera unit, please take note of the correct positioning of the unit for reassembly
Step 20. Half close the phone and release the main flex assembly connector.
Step 21. Carefully slot the flex connector through the C cover.
Step 22. The power switch is glued in place and can be levered out using your shim.
Lower block
Step 2. Remove the battery cover and battery.
Step 3. Remove the four Torx T6 screws in the order shown below and keep them safe.
Step 4. The screws are supposed to be replaced on reassembly, but in practice you can reuse them.
Step 5. Using a thin shim release the clips on the D cover.
Step 6. Remove the D cover now that all the clips have been released.Step 7. A specific tool is supposed to be used to remove the camera assembly which is not available to the general public. This step and the following one are included purely for the sake of completeness.
Step 8. Take note of the correct orientation of the camera for reassembly.
Step 9. Lift up the main PCB.
Step 10. Use your shim to carefully release the flex connector
Step 11. Lever up the keypad using your shim - bear in mind that it is glued in place.
Step 12. If you have been careful removing the keypad you may be able to reuse the glue gasket otherwise it will need to be replaced.
Posted on Jan 15, 2008
I want to know how to remove drum unit just for cleaning only from the machine sharp mx-m464
when you open the front door just below the development unit the is a blue screw remove the development unit and then open the side door then in front of the machine pull the drum unit
Sep 01, 2016 | Sharp Office Equipment & Supplies
Replacement
do you want it to be in repair, or you want it to replace...?
Jun 23, 2008 | Panasonic CW-1006FU Air Conditioner
Just want to remove front panel to clean
Anna, Normally front is not fastened with screws. In case, first check for any screws that could be holding cover in place and remove them. To remove front cover normally you push down on the top plastic frame which helps release clips, while pulling or pry cover off towards you, in the same area.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Clean Window Air Conditioner
LG LWHD1200R Owner Manual How To Remove The Front Grille
https://answers.yahoo.com/question/index?qid=20090815115103AAsYyOK
http://www.geeksonhome.com/how_6562969_clean-kenmore-window-unit-ac.html
Jun 19, 2016 | Heating & Cooling
Can i take my frigidaire ac out of the case without removing it from the window?
Good Afternoon Friend,
I understand that you want to know whether you can take your Frigidaire air conditioning, model# FRA256ST2, out of the case, without removing the case from the window. Yes you are. Below are step by step instructions for removing your air conditioning from the case.
    1)Unplug your air conditioner.
    2)Take the front grill off.
    3)Remove the filter.
    4)There are four panel screws, two on each side of where the front grill and filter were. Remove these screws.
    5)Gently pull out your air conditioner.
    For replacing your air conditioner, follow the steps in reverse. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer light status has changed successfully. Hope this is helpful.
    -Best regards-
    WP
May 31, 2014 | Frigidaire FRA256ST2 WallWindow Air...
My unit has a ton of black mold in the back of it; should I be worried; how do i clean it??? Also i need to know the best way to clean the filter? I just moved in to an apt with this unit and i've...
I would let the managment know about the mold problem, this can be serious. If you want to clean this yourself, use rubber gloves, a brush, and buy a spray bottle of mold remover. The filter should be located behind the front grill. It should snap loose, and they are normally made of a foam material that you can wash in your sink and let dry. Sometimes they remove them a throw them out!! If this is the case, let them no about that also.Please keep me posted.
Shastalaker7
A/C, & Heating Contractor
Aug 08, 2011 | Frigidaire FAC107P1A Wall/Window Air...
The air that it throws is not that cold, i wanted to know which part do i have to change?
the best cure is to take the unit outside use your garden hose to clean the coils ..remove the front cover/ cover switches with tape ..spray coils on both sides real good to remove dirt ..let the unit dry good ..clean filter and it should work like new again..let me know ..good luck/joe/
Aug 26, 2010 | Quasar HQ2051TH Air Conditioner
How to change inside bulb
Normal procedure is to remove case cover to access the bulb.
Usually several screws on the back and some partially hidden on the front to remove. Sometimes the screws require a Torx screwdriver.
Unplug unit and avoid touching any wires.
Replace bulb with exact type.
Jan 07, 2010 | Frigidaire FMV156DC Microwave Oven
How do i remove my st699 honeywell programmer from the wall.just cant do it.
Because there are no apparent screws to remove the front of this unit it can be very confusing if you have not done it before. Underneath and to the right hand side you will find a small notch in the plastic, it can be difficult to see when the unit is on the wall, using a small terminal screwdriver push upwards on the plastic tab which locks the front in place and with a slightly larger flat bladed screwdriver prise the front off bottom first then the two locking tabs at the top.
You will probably find that the back case is fastened to the wall with two screws.
Replacement is simply a matter of snapping the front back into the case.
Jun 30, 2009 | Honeywell Programmable Thermostat Heater
Front indicators
Removing the indicators is a simple process involving the removal of the fairing to unclip and unplug them from the fairing. The plastic press studs that hold sections of the fairing in place are prone to breaking when you remove them but are easily obtained from your local Yamaha dealer and inexpensive.
Jun 21, 2009 | 2008 Yamaha YZF-R6
Buttons don't work. Sometimes when I click Source button several times, radio gets turned on if I have enough luck, but in most cases it's pointless), then I can change nothing. Volume change, programm...
Try resetting it. Remove front panel, on main unit is an indent that says reset, insert ballpoint to reset and replace front panel. Everything should now work although you will need to reset stations and clock.
Apr 18, 2009 | Sony CDX-L480X CD Player
Nokia 6288 Cellular Phone Logo
74 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
