Question about Panasonic SC-AK600 CD Shelf System
Nide code fore a panasonic cd stereo sistem
I got a panasonic nodel # SA-AK600 cd stereo sistemm, when i push the power boton it stais on fore 3 sec and on the scrin it sais f61 and it turns off.
  • Kaberle Mar 14, 2008
    Yes, my SC-AK600 was working fine one day, and the next it would only display F61 for a couple of seconds, and then nothing. I've unplugged it for hours to see if it would reset itself; reconnected all the speakers; tested the power cord, and checked Panasonic online for a solution. It seems to be a faulty power supply, in which case I'm not going to spend exorbitant cash to have it replaced. I haven't removed the casing yet -- need to retrieve 4 CDs, before I recycle this unit. However, I'll keep it for a while to see if anyone comes up with a less expensive (other than a new power supply) solution. Thanks.
  • bluesman525 Aug 07, 2008
    I have the same unit . it will start and play fine but will shut down itselt after about 5 minutes. could it be a chip . unit seems to hae no ext. damage .so it may be a power supply component ..what do I do ?
  • 4 Answers
If you get a tv repair man he can fix and order the part that is the problem it is a twelve pin plug that needs specilist tools to remove. The part is an amplifier chip, common problem with the sa-ak600.
Posted on Mar 20, 2009
  • 82 Answers
Most likely the regulator IC is defective. Part # C5BA00000105.
Posted on Mar 28, 2008
5 CD changer, model sa-ak600. What does code f61 indicate?
F61 means that the power amp has something wrong with it.
It could mean the IC501 has failed or that there is something wrong to the power supply to it.
The good news is the service manual is free online. You can get it by simply putting the model number into google and searching for the PDF of it.
Jan 02, 2016 | Panasonic Audio Players & Recorders
I have a stereo system, sa-ak 78, it wont store and change 5 cds. Think a part is broken, but cant figure which part?
The pladder may not be turning, remove top, and remove clip, now carefully pull pladder off, make a note of the position it go's back in, this will expose some of the key parts.
Mar 17, 2012 | Panasonic SC-AK600 CD Shelf System
Panasonic SC-AK600 CD player says "no disc" when
Your cd laser lens has got weak.get it replaced.
you can replace only the lens or the whole laser pickup.
Dec 29, 2010 | Panasonic SC-AK600 CD Shelf System
My panasonic sa-ak600 cd player doesn't switch on. I checked the fuse inside the unit and found which was good. hopefully, someone can figure it out. thanks
I had the same problem. My unit would turn on, display F61, and turn off. I looked at the manual. It said if you see 'F61', check and correct the Speaker Cords connection. If this does not fix the problem, there is a Power Supply problem. Consult the dealer. Hope this helps.
Oct 04, 2010 | Panasonic SC-AK600 CD Shelf System
My panasonic cd stereo system SC-AK600 keeps telling me that there is no disc even though all five disc trays are loaded, what is wrong with it
sounds like the laser is no longer working. Call partstore at www.partstore.com and let them know what model number you have and that you are looking for a replacement laser for the unit. Replacement is for the mechanically inclined or a technician. The part is static sensitive so I recommend taking the unit to a repair center.
Jan 01, 2010 | Panasonic SC-AK600 CD Shelf System
Radio won't play, display shows only a code of FB-1
Maybe the code error are F 61 for a panasonic sistem that code means bad audio amplifier
Jan 20, 2009 | Audio Players & Recorders
I have a f61 fault code on my sa-ak600 panasonic audio system
Replace IC500 on power circuit board.
The board at the bottom with heat sink.
STK470-090 voltage regulator Sanyo original.
Dec 22, 2008 | Panasonic SC-AK300 CD Shelf System
Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
May 30, 2008 | Panasonic SC-AK600 CD Shelf System
Panasonic SC-AK600 CD Shelf System Logo
1,126 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
