Question about Microsoft Windows XP Professional for PC
Computer shuts down
My sons computer shuts down in the middle of doing homework on a word document for no apparent reason. When we restart the computer all of the folders and shortcuts are gone from the desktop. He is disabled and uses an onscreen keyboard. We thought that might be the problem so we tried another onscreen keyboard. Same thing happens. The school has sent home 3 different computers. Problem happens on all of them. Sometime right away sometimes after several hours. What could be causing this? The school thinks he is doing this on purpose. He definitely isn't. Problem is...it only happens at home.
Please help us.
Joyce
    Problem Solver:
  • 18 Answers
If it only happens at home, then there must be a condition. Make sure that the computer is in a good place with lots of ventilation. The on screen keyboard may use a lot of processing power and so the computer is overheating and then shutting off. If its a laptop, sometimes they like to be propped up on some books so some ventilation can get into the bottom.
Are these computers laptops? Desktops? It could be a power bar issue so try using a different bar, or try moving the computer into another room all together, it could be the electricity in that room. Or the computer may not be plugged in properly if its a laptop...it isnt receiving enough power so it uses the battery until its dead then turns off, check the battery status at times.
I'm not sure what would cause the icons and folders on the desktop to disappear after a restart unless you logged into it differently. If a computer crashes after you place icons on the desktop, it doesn't save the settings of the desktop and so the icons may disappear.
Posted on Jan 15, 2008
Chevy cavalier 2002 shut off while driving, power steering went out and brakes. i turned car off and it restarted what was it and how can i fix it?
Ther is a problem with some computers in that they shut down the engine for no apparent reason. This problem hounded Kia owners as the engine just stopped at lights but restarted with no problems. Check for any fault codes and check for circuit problems with alternator as some cpu's get their power directly from the alternator and it has to be full voltage or they sense a power failure and shut down.
Feb 03, 2013 | 2002 Chevrolet Cavalier
There is a message showing on My Canon MX310 "Check Printer 5B00", how do I fix it? Right before the message showed up I copied a document that printed with a line down the middle.
Try these procedure:
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | Canon PIXMA MX310 All-In-One Printer
I cannot print, the service spooler is not running
In run window type services.msc and the go to print spooler option just stop and restart the service.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP LaserJet 1022 Printer
My computer keeps shutting down for no apparent reason... I hasve a toshiba satellite p10...
Possible causes of the problem:
System overheating
- Virus infection
- Power supply malfunctioning
Solutions:
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
Nov 17, 2009 | Toshiba Satellite P105-S921 Notebook
My computer wont load windows a problem has been detected and windows has been shut down to prevent damage to your computer. unmountable boot volume if this is the first time you seen this stop error...
Your Operating System probably corrupted due to unexpected power failure or any other reason. You may have to setup widows again.
Before reinstallation take backup of all necessary file in a separate Hard Disk from your (C: ) Drive , existing desktop , my documents , share folder, etc. to do this you have to connect you Hard Disk with another workable PC.
After taking all necessary backup, setup Windows freshly and it is recommended to format C drive during fresh setup.
Jul 12, 2009 | Averatec Laptop Keyboard for 3200 Series
Computer shuts down
most pcs will shut down to protect themselves in some way. need a bit more info, age, make etc
Jan 11, 2009 | Computers & Internet
Computer shuts down
Could be the power supply,Try changing the power supply
Jul 12, 2008 | Computers & Internet
Printer locks up
  1. Click Start, Printers and Faxes and double-click on the Lexmark printer driver.
  2. Open the Printer menu and select Cancel All Documents. This will purge the print queue so as to allow the printer to print or uninstall the driver.
  3. If the print jobs are not removed from the queue, click Start, Run, type Net Stop Spooler, and press ENTER.
  4. Click Start, Shutdown, and select Restart. The documents or the print jobs should be removed.
If you are having difficulty deleting the print jobs in the printer spooler, do the following:
  1. Restart the PC in "safe mode". To do this:
    1. Click Start, Shut Down and select Restart.
    2. While the PC is restarting, press the F8 key on the keyboard. Note: Do not hold down the key down, but be aware that you may need to press it several times.
  2. When in safe mode, click Start, My Computer.
  3. Double-click on the (C:) drive.
  4. Double-click on the Windows folder.
  5. Double-click on the System32 folder.
  6. Double-click on the Spool folder.
  7. Double-click on the Printers folder.
  8. Select the contents of this folder and click Delete.
Mar 22, 2008 | Lexmark X3480 All-In-One Printer
Computer shutting down randomly in the middle of everything...even offline games
This can be the result of a virus infection or an infection of other malicious software such as spyware.
Run a thorough system scan.
If this doesn;t help, tell me and we'll go to the next thing to check/do for this kind of problem.
Greetings,
DarkNeogen
Jan 25, 2008 | Microsoft Windows Vista Ultimate Edition
Printing suddenly slows down for no apparent reason
This is more likely a computer issue than a printer issue. The only way to prove it is essentially try the printer on another computer. Preferably one with more RAM and faster CPU.
You could try closing some of the running processes via the Task Manager. This would free up some resources and may help the process.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
Microsoft Windows XP Professional for PC Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
