Question about Body Glove Earglove Sport Headset for Audiovox - 74975 Headset
Earglove sport stereo headphones with palm centro
I just bought these headphones and when fully plugged in i only get sound in the right ear piece. When i plug it into my laptop with the plug adapter they work just fine, so i guess it has something to do with working specifically with the palm centro. any ideas?
  • 1 more comment
  • tomasboman Jan 23, 2008
    Any solution to this problem? I see the exact same thing. Of course the guy at Best Buy said that it will work perfectly and I don't see how it can not work when the 2.5mm plug looks like a standard stereo-mic plug.
  • steadfast Jan 30, 2008
    i actually got some feedback on this, apparently you only hear sound in one ear because the stereo channel sends one signal to that ear piece and the other to the mic, so you need an additional adapter to bypass mic and make the earphones just work as earphones and not a headset, kind of a pain in the ass, on palms website u can look up headphones specific for centro, so best bet is to just buy those and you'll be good to go, unless you wanna do the whole adapter route with a nice set of headphones
  • Anonymous Feb 15, 2009
    Thanks for the info. It doesn't seem right that the box advertises this product to work with palm.
  • 3 Answers
I had similar problems......if your only getting it in one ear...the trouble is likely that the connection is not completely flush. many of the adapters from a standard headset plug (1/8) to the 32 don't seat evenly. trouble is the charging/hot sync port is elevated.....and it renders most adapters unable to lay perfectly flush with the phone. palm makes an adapter; or esle you can try centro accessories for the adapter
Posted on Jan 01, 2009
Yes, I had the same problem.  Glad to see your post as it saves me much troubleshooting time.  Think I'll have to return the body glove set and go with the proprietary set.
Posted on Feb 26, 2008
Ya must be a centro thing , i was reading on another fourm that www.softick.com audio gateway is the solution for bluetooth headphones butt im not sure about wired.
Posted on Jan 29, 2008
Replacing minijack
I use a multimeter to check the connections to the ear pieces. I set it to the diode function. The meter's test probes also have a very low dc voltage and this causes a 'click' sound in the working earpiece. Some earphones have 3 wires, others have 4 wires. In the 3-wire setup, one wire is the common wire. It goes to the ground connection of the mini plug. The 'click' sound on the left ear piece should go to the tip of the connector. The 'click' sound that you get on the right ear piece should be soldered to the 'ring' of the mini plug. The 4-wire type of earphone/ headphones cable usually have two wires that are the same colour. These are the ground or common connections for both right and left. I hope that this helps. A multimeter or vom is a necessity. Len.
Apr 11, 2014 | Klipsch Image S4a black For Android In-Ear...
Jvc headphones retractable cord
The JVC HA-NC250s are a new version of their previous model 100, and JVC claims that they will cancel up to 85% of ambient noise, coupled with better sound. In this case, JVC claims up to 16.5 db reduction at 150 kHz. These on-the-ear headphones are very lightweight at 5.3 ounces and are extremely comfortable. The head band has a reasonable amount of sliding expansion for bigger heads, and the oblong ear pieces themselves rotate and fold flat for storage. JVC uses memory foam on the earpieces, as well as double housing, for extra noise isolation. The earpieces have 40 mm neodymium drivers, which are the same size and type that the Creative Aurvanas offer.The JVC HA-NC250 noise canceling headphones. Note the ear-cushion instruction tab that explains how to replace the hidden battery.
The NC250s come in a semi-rigid black case with a dual airline-plug adapter, a mini-to-RCA phono plug adapter and a 4' detachable headphone cord. JVC includes one AAA battery, which should last approximately 50 hours. A simple sliding switch on the right side turns the noise reduction on along with a small red LED. Learning how to add the battery to the headphones required that I study JVC's user manual. The process involves having to remove the earpiece covering to get to the battery compartment, which isn't at all obvious.
Jul 22, 2012 | Audio Players & Recorders
I have bought several pairs of headphones for my gogear but they all sound like there is a problem with the connection only getting sound through one ear sometimes
The headphone socket in the GoGear is faulty. If you can hear sounds from both ear pieces when you wriggle the headphone plug in the GoGear, then the headphone socket in the GoGear is faulty. This fault can be easily fixed by removing the circuit board in the GoGear and resoldering the headphone socket to the circuit. You need a very fine tipped temperature soldering iron to do this job.
Jan 19, 2012 | Philips GoGear HDD1830 MP3 Player
My tascam us144mk2 works great only problem is my headphones only play in left ear i have a pair with 1/8" plug so i bought a 1/4" adapter and only have sound in one ear i've tried multiple...
Double check that the adapter you bought is designed for stereo. The easiest way to check this is count the number of metal bands you can see on the adapter, stereo headphones will have 3 metal bands separated by 2 plastic bands, whereas mono will have 2 metal bands separated by a plastic band.
If you accidentally bought a mono adapter, this will cause sound to only play in one ear.
Mar 06, 2011 | Tascam US-144 Sound Card
Hello .. Thank you very much . I was playing a music with my laptop and i tried to connect a ear pin for the speaker and all of a sudden the sound went off so you cant hear any sound . when ever i connect...
Plugging-in a set of headphones to the "audio-out" port *SHOULD* cause the internal speakers to become QUIET.
Unplug the headphones, to make the speakers work.
Sep 17, 2010 | Gateway 450ROG Notebook
It plays through built in speaker even when headphones are plugged in
Try a different set of headphones, it sounds like the computer is not recognizing that the headphones are plugged in. Does the computer put sound out through the headphones as well?
Jul 31, 2009 | Acer Aspire One Netbook 8.9" Notebook
No sound from headphone
Worse case scenario is that your left speaker is gone but usually what happens is a break in the cable someplace.Are you using the 1/8" plug or are you using them with the 1/4" adapter. The 1/4" adapter might be worn out but is easily purchased and replaced.The cabling from the plug runs into the left can and from there splits into left and right speakers. There will be a wire that follows the head band under the cushion from left to right. With these headphones there is a swivel above the can and the problem might be in there. Half the problem is getting at the wiring to test it. Usually the plate that the speakers are mounted on is screwed to the back cup and the screws can be reached by removing the earpad. You will need a volt ohm meter to test the wiring. You can also test the speakers with it. Unfortunately most plugs on headphones are molded onto the cable so you will have to start by testing from the plug to the left can. Inside the left can will be a junction point where the main cable feeds the right speaker. Test up to there for right and left and if the connections are good then test the speaker. Hope this helps.
May 14, 2009 | Audio Players & Recorders
Help! no bass sound, low volume
You might want to try using a different size of the earpieces that come with it, and make sure they're inserted fully into your ear. They come with three different size earpieces because people's ears are shaped differently, and having the right size can make a HUGE difference in the sound. If it's done right, it should basically feel like you've just inserted an earplug into your ear.
If that doesn't help, and you've tried another pair of headphones to verify that it's not a problem with your sound source, I would guess you were unlucky enough to get a defective pair.
Mar 17, 2009 | Sennheiser CX 300 Consumer Headphones
Bad connection
It sounds like you have two problems. One is your ipod earphone plug ( phono plug ) needs replacing, and # two is your headphone plug needs replacing.
Nov 30, 2007 | Bose on-ear TriPort Headphones
Radio Communications Logo
502 people viewed this question
Top Body Glove Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Body Glove Radio Communication Expert? Answer questions, earn points and help others
