Question about HP Photosmart 2610 All-In-One InkJet Printer
Error - carriage jam message
My printer is displaying the error- carriage jam, clear jam and pree OK message. I went to the HP website and followed all the steps listed. It cleared the carriage jam message, but then the paper wouldn't feed. I went back to the Hp website to try to fix that problem, then it went back to the carriage jam message and I have not been able to get that cleared up. I have tried everything!
  • 16 more comments
  • Anonymous Jan 20, 2008
    I am getting a cartridge jam, also. When I try to clear it, it never clears and is in an endless loop with a cartridge jam. Thus, I can't print anymore. I am thinking I need a new printer.
  • hello9 Jan 26, 2008
    I have had this printer 5 months , and just encountered the exact same problem.... any help in fixing the carriage jam situtation would be great... maybe this was not such a great printer after all....
  • Anonymous Jan 30, 2008
    I have a HP 2610 print. Had it for 3 years and never had a problem till this week. I keep getting the same error - carriage jam, clear jam and then OK. I tried several times even unpluged it and looked inside the carriage but did not see a problem. Turned back on and still same problem. I am not able to print!
  • Anonymous Feb 26, 2008
    i have the same problem
  • notta12 Mar 01, 2008
    I have the same problem with my 2610. There is no carriage jam that I can see and also paper won't feed. HELP.
  • Anonymous Mar 26, 2008
    This is ****! I called HP and they wanted to sell me a upgrade "At a specail discounted price" Like I want to spend another $375 ! My $30.00 printer works better than this and lasted longer!
  • Anonymous Mar 28, 2008
    I have the same problem, but I also unplugged my printer to get a better look at everything. Now when I reattach all the cords, the printer won't even power up. I cannot turn it on at all!
  • Neeter G Mar 30, 2008
    I've had my 2610 for about 3 years and haven't had too many problems until day before yesterday when the carriage jam message started. Each day it's gotten worse and more frequent. I too followed all the recommendations on the HP website to no avail. Do you think this is HP's way of telling you to buy a new printer? For example, I've had two HP laptops in the last 1 1/2 years...the first was a lemon and the second, a replacement, lasted about a year (warranty just expired) when the hard drive quit. HP wanted to sell me a new hard drive for almost $600.00. Almost the price of a totally new laptop. Their customer service may be rated high but the quality of their products has declined substantially. I am going to use some alcohol and sponge applicators and see if cleaning the rollers and ink carriage do any good. At this point it certainly can't hurt!
  • Anonymous Apr 05, 2008
    I had a paper jam...fixed that, then the carriage jam message appeared.
  • Anonymous Apr 26, 2008
    carriage jam open door,clear carriage jam
  • lladiedii May 07, 2008
    i just started recieving the same error message while printing. This is happening quite often now. I have cleaned and cleaned the printer and nothing. have any advice?
  • Anonymous Aug 27, 2008
    carriage jammed
  • Anonymous Apr 22, 2009
    does HP upgrade your printer for free if it's defective?
  • Anonymous Mar 13, 2014
    printer says carriage jam but there's no paper jam
  • Anonymous Mar 14, 2014
    Was making loud clicking noise
  • Anonymous Mar 25, 2014
    error message reads "carriage jam'
  • Anonymous Mar 29, 2014
    carriage jam erro
    hp 6210 carriage printer jam error
My Photosmart 2610 just started having this same problem today. As many of you have done, I also went to the hp support website and tried just about everything. Finally I discovered the answer to my problem on my own. Here's what I did (you might want to have a wet rag handy to wipe the ink off your fingers):
1) With the printer on, I pressed "okay" to clear the error message. You should immediately hear the sound of the carriage (the contraption that holds the cartridges) moving inside.
2) Open the print cartridge access door (the main access point for the cartridges) and confirm that the carriage is indeed moving.
If the carriage won't move at all, I'm not sure that this solution will help you. However, if the carriage moves from side to side after you press "okay", please read on.
3) This is unorthodox, so bear with me: when the carriage moves away from it's "resting place" (in my printer it's on the right hand side) and is near the center of the printer, unplug the power cord from the printer. The purpose of this is to free up the undercarriage (which was the part that actually was jammed on my printer).
4) Ensure that the carriage moves freely from left to right and right to left by pushing gently on its sides.
5) Move the carriage to left side of the printer so you have room to access the undercarriage.
6) It might be helpful to have a flashlight or some other light targeting the undercarriage for this next part. If you look directly underneath the undercarriage, you should see a foam/spongy product resting in the base of the printer. The purpose of the sponge is to absorb any ink that escapes from the cartridges. Herein lies the problem: over time, as the undercarriage adjusts to enable the carriage and its cartridges to do their work, the undercarriage gets caught on the inky sponge. Note that the undercarriage is fragile, but is moveable by gently pushing it toward the front or back of the printer.
7) Adjust the undercarriage so you can see the sponge and the "axel" (for lack of a better term) that turns to move the undercarriage forward and back. It may take some detective work, but you should be able to determine where the sponge is supposed to lie. Your goal here is to push the sponge down as far as it will go so that it won't obstruct the movements of the undercarriage.
8) On my printer, there was also a small amount of sponge wrapped around the "axel" that prevented it from moving smoothly. I unwrapped it and double-checked that nothing else was obstructing movement.
9) Final step: leave everything where you moved it, shut the lid, and plug it back in. A little prayer never hurts either. Good luck! AIM ID if you need more help: GnarlyVeaux
Posted on Mar 10, 2008
  • 2 more comments
  • irishchickie Nov 06, 2010
    I have to tell ya, this was driving me to drink, so I did. Then I found this info and tried the solution. It worked. Gobs of ink matted to the sponge and to the right of the sponge. Cleaned out the gobs (without chemicals,q-tips,or anything else your thinking of). Just gently use your finger, the ink will adhere! Close and it worked! So the directions are: Pour one large glass of wine Take approx 3 giant sips. breathe Deep and try this fix! Finish wine knowing "job well done" Print away! Thanks Experts!
  • Brunogeek Jun 24, 2013
    This was the ONLY helpful link. It worked. Thank you.
  • sholl
    sholl Nov 15, 2013
    Awesome. This was exactly the solution that I needed. Thanks!!! How come the HP guy on their forum didn't know this?
  • JOANNA DELACRUZ
    JOANNA DELACRUZ Nov 24, 2014
    how do i know what the undercarriage looks like feeling So unsmart
How to solve the message "carriage jam" on hp D5368 printer
Posted on Apr 30, 2010
I too have had this problem, to the point where I thought the carriage was going to break out the end of the printer. On reading the suggestions on this post, I went to work with my torch and found that it didn't look like the sponge had moved, but there were great lumps of gooey ink? in there, so I scraped a lot out and hooked back up again and hoped for the best. It again started to print and then stopped with the paper being a little skewed..... so I then went to work again cleaning the little feeder rollers at the front, the rollers at the back and then the back cover where there are little rollers there.....end result .... my printer is now back working (hopefully it won't be short lived).... not sure what actually fixed the problem.... but at the moment I'm happy for the advice, which at least made me take the time to fiddle a bit.... fingers crossed!
Posted on Oct 24, 2008
I too found it helpful to get in there and fiddle around with all the little rollers, ink build-up, spring-loaded thing-a-ma-jiggs. There was quite a pile of ink under the black cartridge which I also cleared out. don't know what I did, but it did the trick. Oh yeah, I said a little prayer too - nothing like technology to make me humble!
Posted on Mar 02, 2009
This is great. i used a pen to shove the inky sponge down. and IT WORKED!!!!
was at the same time calling HP and got customer svc in india and they said it was broken and to send it back in to upgrade to a new printer.....
Posted on Oct 05, 2008
  • studio143nyc Oct 18, 2008
    i posted the oct 10 post and it worked for awhile but stopped printing altogether. and i looked and the whole sponge fell off the axel to behind the mechanism and now it doesnt print at all. so i am relenting to getting an upgrade from hp. unless someone has a better solution
Display the error carriage jam ,clear and prees OK message
Solution : replace strips (belt)in carriage
Posted on Dec 28, 2010
  • 6 Answers
Posted on May 11, 2010
  • rinku791 May 11, 2010
This worked like a charm for me - in my case there was a piece of paper caught down on top of the inky sponge.
It was the 'turn off the printer partway through the carriage shift' that was the key. If you just manually slide the carriage over, you won't see the sponge and the area underneath.
Thanks!
Posted on Oct 10, 2008
2 Suggested Answers
rockfixya
  • 679 Answers
SOURCE: error - carriage jam message
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
How do i clear a carriage jame an ,sg find nothing wrong
Click the link below to go to the hp printer support page for your printer paper jam. Pay special attention to the rear door , as many people miss that detail when clearing paper jams.Also , you can click on the troubleshooting link at the top of that page, followed by "solve a problem " in the drop down box to get answers for other problems,
Clear carriage jam and press OK to continue Error Message Appears for HP...
Feb 14, 2015 | HP OfficeJet 7310 All-In-One InkJet...
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the...
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
Sep 02, 2008 | HP Office Equipment & Supplies
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Carriage jam
You could try clearing the jam and then removing power from the printer altogether to re-initialize the printer. However, if that fails either the printer diagnostics chip has gone awry or you have a virus.
Oct 28, 2009 | HP Photosmart 4180 All-in-One Printer
Carriage Jam
>follow the steps on this link to clear carriage jam on your printer
>please inform me if this has resolved your issue.thanks
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00243856&cc=us&lc=en&dlc=en&product=421139
Sep 29, 2009 | HP Photosmart 2610 All-In-One InkJet...
My HP Photosmart C7200 has an error message that reads "Clear cartridge jam" What is a "CARTRIDGE jam" and how do a clear it?
'Carriage Jam: Open Door, clear carriage jam, and then press OK to continue' Error Message Displays on the Control Panel
YOU CAN ALSO GO TO THE FOLLOWING LINK:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&lc=en&dlc=en&cc=us&lang=en&product=3382185
Have a good day,
Jun 25, 2009 | HP Photosmart C7280 Laser Printer
Error message
hi,
below is the document that i want you to follow to somehow resolve your issue.
CLICK HERE TO VIEW DOCUMENT ==>> CARRIAGE JAM
Please let me know the outcome after you perform the steps.
thank you so much.
adonscott
Jul 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Mar 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Carriage Jam error always - how do I fix it?
Try resetting the printer (pressing the cancel button and connecting the power supply, check in the HP website if this is correct for your printer model) , after the reset the printer will clear any errors and will recalibrate the mechanism including the paper feed mechanism and the carriage.
Also check if the carriage is moving freely by disconnecting the power and moving it by hand.
Jan 21, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
5,684 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
