Question about ASUS P4PE-X Motherboard
2 gigs of ram
Installed 2 gigs of kingston ram and machine wont even start no video etc. if i take out 1 stick in works fine any suggestions, thxs
Don
  • llfernandes Mar 17, 2008
    I have same problem. I made an upgrade from 1gb to 1,5gb. I made some tests, changing the used mem slots and different mem cards providers and the result was allways the same: the system doesn't boot (no video signal, nothing). Now, with only 1gb works ok.
    Thanks
    President:
  • 2,351 Answers
Re-check your manual at pg. 1-12. 1.9.1 Memory Configurations.
Since you know one bank of memory works fine in a certain slot. Now try the other in the same slot.
Posted on Jan 15, 2008
  • Mike Peluso
    Mike Peluso Jan 16, 2008
    There is a program to test your memory. Since you can use 1 slot to read your memory why not test each with this program. Most memory including Kingston carry a lifetime warranty. You can download it from here:
    http://www.warp2search.net/crystalmark-2...
    Hope this helps!
  • Mike Peluso
    Mike Peluso Jan 17, 2008
    Bios version 1003, is Improvement Memory Module Compatibility. I do not know what version your bios is. This may help. Bios ver. 1107 is the mose recent update. I went through every FAQ and found no problem like yours. I do a lot of work on Asus boards & deal with Asus quit a bit. May I suggest since the above did not fix your problem try a simple phone call to Asus. At 812-282-2787,Tech IL Eastern Time. Your manual will not show this number.
6ya staff
SOURCE:
I had an intel d865 perl motherboard with a 2.8 processor and 4 gigs of ram, computeer ran great for years then one day i shorted the motehrboard and fried it, i ordered a brand new one and installed it...
Thanks for asking FixYa for help. My name is Jeff and I will be assisting you today.
If you are using the same motherboard as the first one, what you are experiencing is too weird to worry over. Is it still under warranty? I'd say you have proved that the MB is deffective. Take it back for a refund or exchange.
If you are in need of additional help, please let us know.
Thank you for allowing us to help you today.
Jan 19, 2011 | Intel D865PERL Motherboard
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
Intalled 2 - 2 gig Ram bios is only reading 3.
Hello.
I believe the ram needs to be on seperate channels to work.
Giving you a link to a supprot manual.
Good luck.
http://www.fixya.com/PostAnswer.aspx?thid=3880661
Jan 13, 2010 | Computers & Internet
Windows XP Professional x64 Will not start up with more than 2gb.
Move your ram into different slots, put different ram in slot 2 or 3, sounds like bad ram, 32 bit apps access ram VERY diferently that 64 bit apps.
Mar 25, 2009 | Microsoft Windows XP Professional x64...
DDR2's only showing half installed RAM
IF THE SYSTEM SAYS YOU HAVE 1GB RAM THAN YOU HAVE 1 GIG OF RAM, EVEN THOU SOMEONE TOLD YOU YOU HAD 2-512MG=1GB.
HERE IS HOW I SEE WHAT YOU ARE SAYING YOU HAVE 2-DDR-2 1 GIG STICKS THAT MEAN IF 1 IS INSTALLED THAN YOU HAVE 1 GB AND IF YOU COULD GET 2 STICKS WORKING TOGETHER THAN YOU WOULD HAVE 2GB RAM.
1 CHIP SET = 1GB RAM
2 CHIP SET = 2GB RAM
YOU MOTHERBOARD MAY NOT ALLOW THAT MUCH RAM, OR WHAT I MEAN THE BIOS MAKE UP THE AMOUNT OF RAM.
TO RULE OUT ANY BAD CHIP SETS OR GOOD RAM OR BAD RAM.
TAKE THE PEACE OF RAM THAT IS WORKING OUT AND REPLACE IT WITH THE OTHER PEACE AND SEE IF IT WILL RUN.
IF IT WORKS THAN LEAVE THAT ONE IN PLACE AND INSTALL THE SECOND PEACE IN THE SECOND SLOT.
IF BOTH CHIP SET ARE GOOD THAN BOTH SHOULD WORK OKAY TOGETHER.
IF THERE IS A PROBLEM, IT MAYBE SOME DUST IN THE MEMORY LOTS
OR THE SLOT MAYBE DAMAGED.
OR
THE CHIP DESIGN LAYOUT MAYBE THE OPPOSITE SIDE, THIS MAY MEANS THE CHIPS MAY FACE EACH OTHER, OR FACE OUTWARD FROM EACH OTHER.
ROD
Mar 14, 2009 | EliteGroup P4M800-M7 Motherboard
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Cannot Install 2 GIG Memory Upgrade
you got the DDR 2 RAM right? and wont boot you say means you don have even the power on in the CPU or no display?
Jun 16, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Jan 17, 2008 | Compaq D310 (287944-CTO-4) PC Desktop
ASUS P4PE-X Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
