Question about RCA RT2390 System
RCA RT2390 Optical Problems
I am having problems with my reciever. one night i dropped the reciver a tiny distance (everything was unpluged) and after i got everything pluged back in and hooked my xbox 360 up with optical there was no sound. everything else works. anyone have any ideas
SOURCE: rca rt2390 lost remote 5 years later lost
I found somewhere called they have the remote for less then $20 bucks ... I lost my remote 3 years ago
Posted on Apr 19, 2009
0 characters
1 Points
Optical audio doesnt seem to work... Does it need to be turned on and if so how do i do that?
put source on SAT. use the remote and hit "set up" use right arrow button until the word "coax" shows on unit, Now your digital.
Good Luck
Oct 14, 2010 | RCA RT2390 System
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
Optical cable is pluged in but the unit wont recognize it.
the problem is that you need to select the source on the remote of the unit and then select setup, you will be able to change the source from analog to digital (i don't remember the setting) and voila! it should work
Jul 30, 2009 | RCA RT2390 System
Rca rt2390 lost remote 5 years later lost electricity reciever reset and no optical input designated cannot designate optical to input source without
Feb 19, 2009 | RCA RT2390 System
KS3102 Digital Optical Input Problem
What I did was turn on the system, don't put in any dvd in, or select an output 1 or 2. Press Menu on the remote, the display on the system display, not on tv should show Speaker, and other options. Select Input, select the one you want to use as the Optical Sound by press enter, then it will ask you on the system display input or optical sound input. Select optical input and press enter it will then say saved. You can then hit exit til goes back to where the display is back on main screen, or just wait til it exit by itself.
Jan 30, 2008 | Koss KS3102 System
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Nov 04, 2007 | Home Theater Systems
Surround help
Hmm. let me see if I get U correctly. you use u'r theater system with a TV and the audio is fed via optical or U have DVD player that you can feed the audio via optical or coax. I think it is the later, if it is U could be having trouble with sound decoding setting of the DVD player itself. It's like mpeg out or PCM out instead of full DTS or 5.1 dolby digital decoding. If this is the case just use u'r dvd remote and check the audio play back settings. If this does not solve u'r problem, pls state u'r set up briefly, so tht I can understand the type of connection u use. Happy troubleshooting Rifaa
Jun 11, 2007 | RCA RT2390 System
Freezes up
your system needs to be servicedtake it to a tech and have him clean it up.
Feb 17, 2007 | RCA RT2390 System
RCA RT2390 System Logo
Top RCA Home Theater Systems Experts
Are you a RCA Home Theater System Expert? Answer questions, earn points and help others
