Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Need problem diagnosed and instructions on how to self fix
Have colored lines of blue, red, green surrounding images
  • Mad At TV Jan 15, 2008
    had 3 solutions sent
    yours would have been better if you told me the part number etc.
  • 143 Answers
Your convergance ics are out or have bad connections this is a very easy repair just solder them if that dont fix the problem then replac then
Posted on Jan 15, 2008
    Scholar:
  • 128 Answers
Try this out. http://www.support.philips.com/support/html/index_us_en.html
This is the philips support page. If it does not help, plz do not give me a bad rating. Just say that it did not help and I will assist your further. Thank You. :)
  • Omair Chughtai
    Omair Chughtai Jan 15, 2008
    gimme a sec i think i found somethin that could help
Danco instructions
Umm, yeah I think so....
Nov 10, 2013 | Danco Home
My mitsubishi vs 6047 has been in unheated storage for about 4 years. now picture is very blury. when words are on screen large letters are legible with small white horizontal lines dancing side to side....
Does the picture look like this?
If so I believe your CRT liquid coolant has gone bad and needs replaced.
How to diagnose bad CRT Coolant:
Note: This problem will only affect the GREEN and BLUE picture tubes. The RED CRT is never affected, because the wavelength of the red light does not promote this algae growth
General Symptoms: Washed out, blurry picture, red portions mostly OK, GREEN images have halos, BLUE portions of images may have halos or be missing entirely.Turn the color level control all of the way down and remove the screen and/or the cabinet that contains the mirror. (different for different models) Do not turn the set off or the color level control will reset to preset levels. Look directly into the picture tube lens while the set is on. First look at the RED CRT. Observe the scan lines in the picture. These same lines should also be present in the green and blue picture tubes.
After looking at the RED CRT for comparison, look into the GREEN or BLUE CRTs. If it is contaminated, it will look like there is a layer of film that you have to look thru to see the picture. There may also be swirls and other various contaminates forming. If it is not as clear and sharp as the RED CRT, it is contaminated, and you should change the coolant fluid. IF you wish to tackle this I will supply more information and instructions. This task is medium to hard for non trained people.
Let me know if you wish to get the instructions on changing the fluid.
Jun 09, 2011 | Mitsubishi VS-6047 60" Rear Projection...
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
The Blue color is double imaged and when i do the magic focus, red and green do fine but blue the "bars" at the top are smudged and there are no bottom bars showing.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 27, 2011 | Hitachi 53UDX10B 53" Rear Projection...
There is a green line that surrounds things, like a 3d image. the green is out of allignment. Can i order the parts i need?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
69189a5.pngSOLUTION
Jan 22, 2011 | Hitachi 53FDX20B 53" Rear Projection...
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
MITS WS-65869 The green CRT is creating a warped image.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi convergence Problem
You only have 3 colors Red, Blue, and Green. No black or yellow. I would say look for self test diagnosic on here or other sites.
Jan 13, 2008 | Mitsubishi VS-60607 TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
