Question about Sony FD Trinitron WEGA KV-32FV300 32" TV
Initial Setup This display stays on the screen. Auto Program CH+ Exit CH- Will not go away.
  • Anonymous Jun 26, 2008
    Same problem. Also flashes video 1, video 2, etc....
  • Anonymous May 16, 2009
    the initial setup screen flashes on and will not go away
Resoldering your IC Program
Posted on Jan 15, 2008
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
To perform Auto Program again
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
To reset the TV to factory settings
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
A pop up that will not go away Initial setup auto program :(ch+) exit (ch-) nothing works!!! help!!
you need to reset the TV it can be from the remote in your case it can be only from the inside of the TV if you think you know how to open the TV you will find a reset button on the main board. if not take to service
Aug 22, 2010 | Sony Televison & Video
How do i get back to the initial set up screen i set it on antenna and have cable
Dynex has too many different kind of on screen display menus. I got one here is Menu à Setup à Tuning Band à Cable/Air (you can select Cable) à Auto Ch Search.
Hopefully it solved your problem.
May 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Describe your Sony FD Trinitron WEGA This started
I have the exact same problem. If you get anywhere (I can't) please contact me at tbiasi@hotmail.com. If I figure it out, I'll get back to you.
Good Luck.
T
Sep 09, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
After six yers of flawless use, a notice comes up
try starting the tunning and restoring the programs from scratch
May 02, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
Turn the TV on.
2 Hold down on the remote control.
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Auto program message
welcomejee said the problem is a result of dry solder on the 80 pins IC mounted at the rear side of the main board. It can be resoldered.
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
The "Initial Set Up" Box continues popping up and will not go away despite auto programming
Sounds like you are skipping a step....consult owners manual
for procedure...if missing manual,download a copy...google Sony tv owners manual..............................T.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-32FV300 32" TV Logo
218 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
