Question about HP Compaq Presario V2000 Notebook
It does not works properly.
My computer starts up but only so far then it says on a whole black screen
"We apolegise for the inconvenience, but windows did not start successfully. A recent hardware or software change might have caused this.
If your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect you files and folders, choose Last Known Good Configuration to revert to the most recent settings that worked.
If a previous start up attempt was interrupted due to a power failure or because the power or the reset button was pressed, or if you aren't sure what caused problem, choose Start Windows Normally.
Safe Mode (Useable option that I have tryed did not work)
Safe Mode with Networking (Useable option I have tryed did not work)
Safe Mode with Command Prompt (Useable option I have tryed did not work)
Last Known Good Configuration (your most recent settings that worked) (Useable option I have tryed did not work)
Start Windows Normally (Useable option I have tryed did not work)
Use the up and down arrow keys to move the highlight to your choice."
That is all it says and I would greatly appreciate the help I have tryed using all the CD's that came with it and nothing worked and that is all i can think about telling you now thanks.
  • Running Jan 16, 2008
    i tryed this but it froze up when it said Starting Windows i did this before and left it for 3 days and nothing happend sorry but you got anything else?
  • Running Feb 03, 2008
    ok but i have to try it i am haveing a lot of problemd with the dics so give me a while k thanks
    Genius:
  • 1,601 Answers
  • 3 more comments
  • Thomas Christopher
    Thomas Christopher Jan 16, 2008
    Have you tried setting the bios to factory default?
    Thomas Christopher Jan 17, 2008
    The bios message comes up before the Windows splash screen. Cold restart and watch for the message to run setup.
    Thomas Christopher Jan 18, 2008
    Running:
    You can do an "in place" install of xp which will re-install xp as a repair install. Here is a link to a article on microsoft's knowledge base site.
    http://support.microsoft.com/default.asp...
    I have had to use this several times and it works well. Just remember that it will install the original version of XP, so you will need go to windows update and reinstall updates
    Thomas Christopher Jan 27, 2008
    Please rerate to FIXYA if this worked.
    thanks
    Thomas Christopher Feb 03, 2008
    ok.........
My HP Pavilion a1101n will not start up properly. It sends me to a window that says sorry for the inconvenience, but Windows did not start successfully. A recent hardware or software change may have caused...
Power down. Power up. Before the Windows screen appears, Tap < F8 > during startup until the Windows Advanced Options menu appears. Press < Down Arrow > until Repair Your Computer is highlighted, and then press < Enter >. In the System Recovery Options window, click to select your language, and then click Next.
May 29, 2017 | HP Computers & Internet
WHEN I TURN MY WINDOWS XP ON IT HAS A BLACK SCREEN WITH WHITE WRITING SAYING, WE APPOLOGIZE FOE THIS INCONVENIENCE, , BUT WINDOWS DID NOT START SUCCESSFULLY. A RECENT HARDWARE OR SOFTWARE CHANGE MIGHT...
Try safe mode.
If that works, there is a card or software that has failed.
Checking the cards is easy, take them out one at a time and restart, for motherboard features, shut them down one at a time.
For software, did you load anything new, even updates, if so remove them.
Mine turned out to be a bad PCI card for a scanner.
Feb 18, 2010 | Computers & Internet
Screen seems to be not working properly
try using a different monitor, borrow one if you have to, if the monitor works on your computer, then it simply means you need a new monitor. As far as the computer shutting down, it may be recording the bad monitor as an error in the loading process and automatically shutting down.
Mar 15, 2009 | HP TouchSmart IQ770 PC Desktop
Windows Won't start
Hey,
You can fix this problem by installing windows again from the windows installation cd or from the recovery media that came with the computer.
Let me know if you need anything else.
Thanks,
Ekse
Feb 16, 2009 | Compaq Presario 700 470024-192 Notebook
Having problem with start up on Hp Pavillion dv8000
Try choosing "Last known configuration that worked" if this does not fix you problem, then reboot once more, and while it is booting up tap the F8 key and select safe start.
Ps. you may just need to do a fresh re-install
Jan 18, 2009 | HP Computers & Internet
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
It won't work!
Pop an XP CD in and Boot from it.. When it gets to the point where it says "Press "Enter" now to install Windows or Press "R" for the Repair console"? press R.. This will take you to a Command C: prompt after it asks which "Windows installation you want to access" Hit 1 Then Enter (generally for C:), If you had a Password it will have to be entered and prompt. If it asks and no passwrd is there hit enter. When you get to C:/ type: "fixboot" And hit enter.. Y for yes/enter. It asks for verification. Then Type" fixmbr "and hit enter. Same verification. Then type "chkdsk/p"and force checkdisk to run even though the file system may have apeared to be fine.. (Saves a step) Type exit after all are done and try rebooting from the hard drive.. Good luck!..
(If It does not work change the hard drive)..
Jan 16, 2008 | HP Compaq Presario V2000 Notebook
Hp pavillion zt 1170
I am pretty sure you have a corrupted operating system here, or have somehow gotten corrupted video drivers. Boot to safe mode and change the video drivers to Microsoft VGA Generic and reboot and see if that fixes it, If it does, you can experiment with installing updated drivers for that machine available on the HP web site.
Also run a disk check on all drives; sounds like you might have some data loss.
If this does not fix it, consider reinstalling the operating system and then patching it to the highest level possible.
If reinstalling the OS does not work, you might have hardware problems with the screen or motherboard, though this is pretty rare, and is a different matter to troubleshoot.
Good luck...
Nov 29, 2007 | HP Pavilion zt1170 Notebook
HP Compaq Presario V2000 Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
