Question about Kenmore 98702 Stacked Washer/Dryer
Stacked kenmore tranny problem?
My kenmore is 4 years old and today i heard a loud noise and then the belt started smoking. i took off the front panel and turned the bottom pulley on the tranny and it would turn clockwise but it would not turn when i turned it on in any cycle, could this be a bad tranny or something else?
  • jblack3900 Aug 02, 2008
    The washer on ours filled up with water, will not agitate, or spin. There is a faint humming noise and then smoke starts to pour out of the unit.
  • 46 Answers
Yep. belt started smoking because motor is turning and not the tranny.
Posted on Jan 29, 2008
My Kenmore d433 dryer won't start
you good have a broken belt , are motor over heating if you know how to take off front panel to check an see is belt are motor make sure u unpulg are trun power off are just call appliance pair service ok hope this will help out
Jun 05, 2017 | Kenmore Dryers
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
Loud noise burning smell
Most likely a belt problem or a worn out tensioner. You left off the year, make, model and engine so it's a guessing gamet. Read this post on how to track down the source of noise
http://ricksfreeautorepairadvice.com/diagnose-squeak-noise-creaks-and-squeals/
Diagnose squeaks creaks and squeals
Oct 05, 2017 | Cars & Trucks
Squeeky Noise
Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
Nov 22, 2008 | Maytag MDE4806 Electric Dryer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore 94802 washer belt overheats, smokes, and melts
sounds like perhaps the trannsmission has locked up and is not spinning freely, therfore the belt is meeting resistance and not turniing.( try turning the trans. pullley( where the bsck of belt is wound)does it turn freely??? try turning the tub from inside does it spin at all??? before i condemn the tranny i would check for article of clothing fallling between the tubs, holding from spinning, also ive seen (nails/screws/bra underwires,etc..) poke through onr of the holes with in the tub abd stuck to the outer tub also preventing the tub from spinning, look closely to all the inner basket holes!!!
Apr 08, 2008 | Kenmore 94802 Front Load Stacked Washer /...
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Agitator will not move
Jac, my suggestion is this. The "reverse" gear in the transmission has locked up. The burning smell is coming from the belt. The motor is trying to spin the belt to turn the tranny but it won't turn  'cause it's locked up this causes the belt to burn.
If it's less than 5 years old, the tranny is under warranty. Contact Frigidaire and give them the full model and serial number and schedule a repair. (ask them to bring a belt with them when they come. you'll need one.)
Oct 11, 2007 | Frigidaire FGX831CS Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Logo
83 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
