Hi! I recently dissasembled my Toshiba Satellite A70 to clean out the cooling fans and heat dump(don't worry the warranty died years ago). When I re-assembled it and turned it on, the screen is all wonky! Only about 70% of the width of the monitor (from left to right) is being used, with about 5% double capturing a certain portion of the screen image, and 25% being nothing at all. Have I crossed a wire somewhere?
Try to connect it in a external monitor if it works. If so maybe your LCD is already damage.
Posted on Jan 15, 2008
    Problem Solver:
  • 23 Answers
It seems that there is a problem with the flat ribbon cable that connects to the monitor, one of the connectors of this ribbon cable is not plugged in properly, or a portion of the ribbon cable is getting crimped.
I suggest taking it apart again and checking the cable.
Hope this helps
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Toshiba Satellite M30 Problem
Power adapters fail because of power spikes. You can do a preliminary test of your system's adapter by plugging it into your notebook and checking to see if the computer indicates that its battery is charging. Usually there's an LED (light-emitting diode) that flashes when the battery is charging. If you can't test the power supply using this method, take your notebook computer to a technician who can test the adapter.
Feb 16, 2008 | Toshiba Satellite M30 Notebook
Hi there is a toolbar coming up the whole time saying,,,,,WARNING a problem with the cooling system has been detected, please turn of the computer and return for service immediately
Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
Welcome to FixYa! Based on the error you have received, this means that the cooling fan of your laptop needs to be cleaned and checked at. This is a common problem with any toshiba laptop. I suggest checking the heatsink of your laptop. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
  5. If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Hope this helps! Thank you for using FixYa!
Jul 27, 2011 | Toshiba Satellite 1715XCDS Cooling Fan...
Toshiba SatelliteA70 over heating, automatically switch off, white screen problem, after a couple times it got automatic switch off, its getting blue screen error, saying that memory dumping, finally it...
DUE TO THE HOT SUMMER SOME LAPTOPS GET TOO HEATED , SO PLS USE A COOLING PAD UNDER YOUR LAPTOP. OR FOR INSTANT SOLUTION KEEP THE LAPTOP IN SLANTING POSITION SO THAT THERE IS ENOUGH SPACE FOR AIR TO CIRCULATE UNDER IT.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Toshiba Satellite A70-S249 Notebook
Cleaning my fan on my toshiba satellite c655 i need to know how to take it apart to get to the fan
There may be information on this site that will help you;
www.insidemylaptop.com
They specialise in photographing dissasembly of laptops and most Toshiba laptops are put together the same way, so I hope it helps you.
Feb 04, 2011 | Toshiba Satellite C655-s5090 Notebook
How to boost cooling fans on Toshiba SATELLITE A70 Laptop
There is no way to "boost" the fans. I'm assuming the fan runs.
Buy a laptop cooler from a local store. They come with USB fans that will assist with cooling. Also, never use a laptop on anything but a hard surface, never on a blanket or on your lap.
Sep 03, 2010 | Toshiba Satellite A70 Notebook
My toshiba satellite a60 keeps shutting down after 1 minute or less. i cleaned it recently, the coolers are working fine i don;t know what the problem is. pls help urgently!
HI there if you clean the internal system then i suggest you remove the ram & cooling fan & fix it back properly. Another thing is watch the keypad and try to found is there any key pressed or not. I hope you will found the error & solve the problem. Thanks.
Mar 24, 2010 | Toshiba Satellite A60 Notebook
Toshiba Satellite a70-s256 fan issues
Instead, turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air.
Give your computer a "blow-job", to remove all the dust that has accumulated inside your computer.
The dust has been acting as "insulation", forcing the fans to run faster, and with more noise.
Cooler computer -> quieter computer.
Jan 16, 2010 | Toshiba Satellite A70-S256 PC Notebook
Cuts of
Becarefull,
Seems like your laptop is overheating, and it shutsdown as a way to protect the processor.
With a vaccum, **** the dirt that might be trapped in the fan or fans.
This should help.
If not, then you need to open laptop and perform a deep cleaning on the Heatsink, and apply fresh heat release compound on the processor.
Please don't forget to rate this answer if it helps
Nov 10, 2008 | Toshiba Satellite A70-S249 Notebook
Toshiba Satellite Laptop Cooling Failure
The fan has failed - warranty if in the time period since purchase.
Jun 30, 2008 | Toshiba Satellite Laptop Cooler
Computers & Internet Logo
Alun Cox
David Payne
David Payne
