Question about Compaq iPAQ H3850 Pocket PC
Stuck on pop up screens
I am stuck on the pop up screen i have not use my pocket pc and the battery run out and now that i want to use it i can not
2 Suggested Answers
  • 13433 Answers
SOURCE: How to fully reset my 3955 ipaq pocket pc
Heres how to fully reset it
Posted on May 19, 2008
SOURCE: I can't make my IPAQ pass the align screen
Replaced LCD touch screen in Australia.  Cost $95.00 AUS Thanks for Fixya help you where really great.
Posted on Feb 17, 2009
0 characters
1 Points
I was trying to update the Bios when my pocket pc went to a screen that has the word "Serial" at the top, a hp blue logo in the center with the word invent underneath it and at the bottom it has a v1.08. I...
Not a problem it happens just go to download the bios driver and use it on windows xp it will not work with anyother windows and run it with your ipaq connected to the pc. This will reinstall the complete bios software and bring it back to factory.
Aug 10, 2010 | HP iPAQ H2200 Pocket PC
Screen stuck on "Serial (Top)-HP blue logo Invent (Center)-v1.08"
have you tried starting the ROM update over. if it recognizes part of the update it may give you an out back to your previous version. good luck.
Jan 19, 2010 | HP iPAQ H2200 Pocket PC
My i-mate pocket pc screen does not get aligned
Hi. You should tap the screen with the stylus carefully and with a little bit more pressure, accurately on the cross sign evertime it appears. When you successfully tap each cross sign once, you would be able to pass to the other settings, but in case there is a problem passing though the screen aligning, here is a small tutorial about how to bypass that screen through your PC: ( Hope this helps.
May 27, 2009 | i-mate Pocket PC
Axim x5 Won't get passed alignment screen
I've heard some keep aligning and after a time it eventually works. 200 to 300 times.
I tried 7 then took the advice of a techie that said to gently twist it like wringing out a wet rag. Put hands on the top and bottom and gently twist back and forth.
It worked for me.
Be gentle
Apr 18, 2009 | Dell Axim X5 Pocket PC
have you pulled the battery for 5 minutes and then retry?
Apr 08, 2009 | Pantech C810 Pocket PC
Feb 12, 2009 | Compaq iPAQ H3955 Pocket PC
Align screen
i have the same problem wat to do i am stuck wit align..
Aug 13, 2008 | i-mate PDAL Pocket PC
Stuck On Align Screen
This happened to me also. Drain the battery completeley and then do it again. You may have to do it a couple times but it will finally take.
Mar 20, 2008 | T-Mobile MDA
Axim x30 screen blanking
I've seen this twice>
take battery off pc and plug it in.
if it stops replace the battery.
if it does not your charging circuit in the pocket pc is gone south.
Mar 14, 2008 | Dell Axim X3 Pocket PC
I-mate jama
wait for a few seconds, then tap on screen when it asks for. Align it, cut-paste, then it should do.
or if it stucks on first screen only, then put your stylus to reset hole to perform a soft reset.
Jan 23, 2008 | i-mate JAM Pocket PC
Compaq iPAQ H3850 Pocket PC Logo
21 people viewed this question
Top Compaq PDAs Experts
Cosma Papouis
Cosma Papouis
Level 1 Expert
Are you a Compaq PDA Expert? Answer questions, earn points and help others
