Question about Insignia IS-LCDTV32 32 in. Television
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change menu to input menu any ideas?
    Genius:
  • 1,127 Answers
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Posted on Nov 29, 2009
SOURCE:
My son some how used the universal remote to set the pass word on the V-chip controls. Now I am locked out and cant get any channels.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Mar 05, 2011 | GE Televison & Video
My samsung le32r74bdx remote control wont change channels and cant turn volume on tv up or down
You can verify that the remote is working. Get a digital camera with a LCD display.
Aim the remote at the camera lens and press the volume and channel buttons. If you do not see
a flash through the camera the remote is bad or the batteries are dead.
If you know someone with any samsung hdtv remote, you can borrow it and try the volume/channel
to see if the tv remote receiver is good.
Feb 08, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
How do you tune in a alba tv with no remote control
On alba tv model aelkdvd1988 you tune the channels without the remote as follows:
Push menu button on top right of tv
Use channel + to scroll to installation
Push volume + to accept to enter install menu
Use channel + to highlight auto tuning
Use volume + to accept.
Keep using channel + to navigate menu and volume + to accept highlighted opinions until tv is tuned in
Feb 28, 2010 | Televison & Video
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Changing channels by itself
bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
Oct 05, 2008 | Beko 324250WN 28" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Insignia IS-LCDTV32 32 in. Television Logo
655 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
