Question about Kenmore 98702 Stacked Washer/Dryer
Dryer makes a loud squeaking/squealing noise while drying.
Our stackable dryer starts to squeak loudly after a few minutes and continues until the end of the cycle. This is so loud that you can hear it from outside. It seems to dry the clothes fine but the squealing and screeching is almost unbearable. Any solutions or suggestions? Thanks. Tracy Miller
  • 4 more comments
  • pat1957 Mar 23, 2008
    how do you get to the ball bearing. i.e.: how do you tear it down?
  • teetee1955 Apr 03, 2008
    how to remove panel on dryer
  • so-upset Jun 09, 2008
    I have exactly the same problem, but the Model of my Stacked Washer/Dryer is Frigidaire. Are all model's Stacked Washer/Dryer are like that?
  • eriloo_30 Aug 18, 2008
    hi we have a kenmore stackable. our dryer started out with the squealing noise for awhile, it stopped for a couple weeks now it has gone to a grinding noise, drying clothes fine but grinding untill the end of the cycle could that be the ball bearing.
  • bk1020k Jan 01, 2009
    I have the same problem. How can I replace the belt?
  • Mzlove30 Mar 23, 2009
    I have the same problem. If squeales while drying but it may or may not stop during. What in the world is this?
    Sniper:
  • 88 Answers
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Posted on Jan 17, 2008
  • Matt Trainum
    Matt Trainum Dec 02, 2013
    Dan's comment is really helpful. Thank you. Is the bearing you are referring to under the dryer tub? Do I have to take out the tub to get to it? I have lubricated the area I can access through the panel but that is not really having any effect. I think I may be missing something but I can not figure out how to get the tub out of this particular kind of model
I need electric diagram of dryer and the schematics of model 98702
email: elena@coqui.net
Posted on Aug 23, 2008
Kenmore stackable dryer squeaks So loud. How can I fix this.
A model number would greatly help, the dryer is most likely made by Frigidaire for Kenmore, your squeal is probably from a dried our drum support bearing at the rear center of the drum. If this is the case, an experienced repairman is advised to make this repair. Pleazer Appliance...
May 18, 2014 | Dryers
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer makes loud noise while drying.
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
Loud squeaky noise when dryer starts, noise stops after several minutes
I would replace the belt that turns the drum. It is probably wearing out and that is causing your noise.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
12,073 people viewed this question
Sal De
fordexpert
Robert Rankin
