Question about Jenn-Air WW30430P Stainless Steel Electric Double Oven
LED Display fading
I have the Jenn-Air wall oven model WW30430P and the LED display is fading, I can still see the clock but can no longer read the temperature nor the timer. If anyone can diagnose the problem and especially the part numbers I would need to replace I would be grateful.
  • 2 more comments
  • rwfo Apr 25, 2008
    I have had the same problem for many months. Jenn-Air repairman first replaced the display board -- no change, cost $340. Next changed all circuit boards; still no change. BTW, a good whack on the display usually brings the display back for a while. The repair guy won't try again because he says he doesn't know what to do. I spoke with Jenn-Air customer service. They said that they would check the problem and call me back. Never did and won't return phone calls. Only suggestion was to try another repairman.
  • Anonymous Jan 01, 2009
    I have the same problem, lights are dim and have been for about 6 months. Glad to know that replacing the insides won't necessarily work. I wish I had the ability to solder in my own as suggested.
    Time to rip out the Jenn-Air and install somethign better!
  • mikezav May 11, 2010
    nix the fan issue it is working after I removed the panal again and reseated all the connections. The display is working perfectly thanks again as the capacitor cost $1.39 and I paid $10.00 at a TV repair shop for them to the soldering.
    I did exactly as described and replaced the bad C3 capacitor with the one from radio shack and display is fine though I noticed the fan is not working now - any thoughts?
  • 3 Answers
As noted in solutions to other Jenn Air ovens, this is often solved by replacing the capacitor labeled C3 on the circuit board that contains the display. Oven heat apparently causes it to fail over time. This is a solder connection to the circuit board. Not hard if you have any experience with this kind of soldering it is straightforward.
Seven phillips sheet metal screws to remove panel assembly, plus two electrical connectors. One ribbon connector from touch panel to board, then four 1/4 hex sheetmetal screws to remove circuit board from touch panel and metal frame. Then soldering iron.
It did work on a 40300 dual unit, which is same as this model except for cosmetics.
Capacitor is 35 volt 68 microfarad. Radio shack has 100 microfarad, which one report says works. Radio shack doesn't have a 68, but they do have 22 and 47 which mounted in parallel give 69, which is within tolerance. That's what I used. The capacitors cost $1.29, less than 1% of the cost of a new circuit board.
Posted on Jan 01, 2009
  • JTcincinnati Oct 21, 2010
    I wanted to second gregglee's rec; our light went out (or become extraordinarily dim) and lead to the broiler not functioning properly. I went to Radioshack and purchased two axial capacitors, 22 and 47uf, for under $3 bucks. De-soldered the capacitor labeled C3 on the control board from the reverse removed the bad part, tied the two new capacitors (positive to positive), soldered the wires, inserted through circuit board and then soldering to board. Whole process maybe 15 minutes after returning from the 'Shack.
    Also had to replace door hinges, another common problem on this model of Jenn Air. The screws at the top of the hinge place first have to be removed. These replacement parts were ordered via appliancepartspro.com which was both the cheapest and fastest to deliver.
    New Friend:
Made the change using 2 capacitors but there is no change. Any other suggestions?
Posted on Apr 30, 2013
We have this happen once after 4 years. Just like others, we replaced the display board, it seems to work fine. It might have something to do with the oven doors are not closing correctly. Please refer to the same model with topic, "The oven doors are not closing all the way".
Good luck.
Posted on Oct 03, 2008
We've had this happen twice. Make sure you don't spray the screen with any cleaner...liquid is what causes this. Had to replace the board...$390. Sorry.
Posted on May 17, 2008
GREGGLEE HIT THE SOLUTION ON THE NOSE. I USED THE 100 MICROFARAD AND HAD THE JOB DONE IN LESS THAN 30 MINUTES. MAKE SURE THAT YOU ALIGN YOUR NEGATIVE LEAD FROM THE CAPACITOR TO THE NEGATIVE HOLE IN THE BOARD OF THE C3 CAPACITOR LOCATION (IT'S MARKED BY A SOLID BAR NEXT TO IT). GOOD LUCK - IT'S NICE TO SEE THE TIME AND SETTINGS AGAIN.
Posted on Jan 20, 2009
Tnx for the inputs. I found the perfect solution -- I ripped out the ovens and sent them where they belong, the dump. Replaced with a different brand. Will never buy Jenn-Air or related brands (Maytag) again, nor will I do biz with the dealer who took my money without fixing the problem.
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - ManualsOnline.com
fitness.manualsonline.com > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Sep 24, 2015 | Jenn-Air WW30430P Stainless Steel Electric...
The oven is randomly beeping and the display is reading f7
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic oven control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Apr 10, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Jan 31, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Am negotiating a home inspection on a house with WW30430P Jenn Air Wall Ovens; neither of the doors close. Is there a solution?
There are several models of Jenn-Air ovens that had issues with the door closing. The only solution is to replace the door hinges (unless the doors themselves are bad, you can see this if you open the door, the porcelain on the door will be bulged and cracked right where the hinge joins the door). If the doors are bad, the hinges and the interior door panels need to be replaced. Hope this helps!
Dec 16, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-air ww30430p
this can be the light unit or the power unit supplying the voltage to the light unit. both cost about$150 each. I need a wiring diagram or know the voltage that comes out of the epower supply
Nov 14, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
805 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
