Question about Spectra (SS213) 13 in. Portable Television
Strawberru shortcake tv turns on then right back off
I have a 13" strawberry shortcake tv when you press the power button the red light will come on and you can hear the tv click on then the power goes right back off, if you press power again nothing happens, but if you unplug it then plug it back in , it will do the above mentiond again.
I JUST HAD THE VERY SAME PROBLEM. wHAT I DID WAS TURNED THE TV DOWN WITH THE SCREEN LYING ON THE FLOOR THEN I UNPLUGGED IT AGAIN AND WHILE IT WAS YET DOWN I REACHED MY HAND UNDER IT AND PRESSED THE POWER BUTTON ONCE MORE THEN IT POPPED BACK ON.
Posted on Aug 21, 2008
I am having the same problem.
Maybe this weekend I can try and track it down.
If you don't know what your doing DON'T OPEN the case.
I will post when the findings.
T
Posted on Apr 02, 2008
    Problem Solver:
  • 10 Answers
Sounds like the power supply may be going out, or check and see if there is a circuit breaker button on the back. Otherwise there may e a blown fuse that is internal. Don't open the back unless you have training on what is safe to touch as the picture tube can maintain a HUGE electrical charge that can stop your heart if you accidently touch the wrong thing. Sounds like a weak power supply tho. Jay
Posted on Jan 21, 2008
Should you cut fresh strawberries to freeze or freeze them whole
I have found either way is fine. I leave them whole if I'm going to use them for a particular dessert and I think it would make a better presentation. If I'm going to make strawberry jam, jelly,syrup or even shortcake sauce I cut them in half or quarters.
Feb 23, 2014 | Cooking
I need the dish network remote code for the durabrand 13" tv
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Jun 24, 2010 | Durabrand BH1304D 13" TV
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
I need a code for an older zenith tv 13"
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Aug 01, 2008 | DISH Network IR Remote Control
Univseral Remote Code for SS213 TV
I don't think there is a Direct TV remote code for this type of television. (Strawberry Shortcake). I'm assuming the reason is because this is such a cheap, generic tv that Direct doesn't recognize it. "Strawberry Shortcake" isn't as big as "Hello Kitty" I guess.
. This is sad because even though the big, pink power button has popped off to where you have to press the little rubber nub, my daughter has been using hers for well over two years where many reviewers have given the tv model bad reviews of breaking down after only 6 months. Hers did not come with a DVD player, although it IS a SS213 model.
May 07, 2008 | Spectra SS213 TV
Need tv code for a Spectra SS213 TV (Strawberry Shortcake) Just had Dish Network installed. I would like to turn the Strawberry Shortcake tv on and off
Codes are hard to come by for this brad as it more than likley is s a sub brand for a major mfg. however you can take your dish remoter and use a powerscan to find a correct code. do this by holding down the SAT button till all lights light up at the top, then enter the code 500 then press pound, Now press the SAT again till they light up then release, then press teh big red power buton once, then press teh blue up arrow onece every 2 seconds until you tv shuts off, ( dont go to fast or you will pass up code. as soon as your tv shuts off, press the pound key and your ready to go with power and volume.
Sep 20, 2007 | Televison & Video
Not Receiving Cable Signals
100% you have or a faulty tuner inside that has to be checked for dry joints or it has to changed completely. Patrick
Aug 26, 2007 | Spectra SS213 TV
Restart ss-2250 strawberry shortcake dvd player after prog. scan snafu
You should be able to simply shut the unit off, & turn it back on after a few minutes. This will reboot the player & it should perform normally. If this fails, look for a tiny reset switch somewhere on the unit. It will be marked, but may be a tiny hole with very small lettering, that requires a pencil point to activate.
Jul 09, 2007 | Spectra Strawberry Shortcake DVD Player
Spectra (SS213) 13 in. Portable Television Logo
226 people viewed this question
Top Spectra Televison & Video Experts
mikemail1
Tom Chichester
Duarte Giron
Duarte Giron
Are you a Spectra Televison and Video Expert? Answer questions, earn points and help others
