My Exilim S600 could not be powered up on battery but when put on the cradle, it is able to power up to play the slide show on cradle.
The problem is it did not charge the battery and the CHARGE light did not light up.
Before I go to get a new battery, will need some advise from those who have similiar prolem on their Exilim S600 or know the cause of it.
Good day on you sir , you have same problem about my friend of mine,, Who have also Exillim S600..
Two Problem you may encounter for that 1st is you need to change battery for that and the 2nd if it not function after you change battery its mean that theres a problem to your current supply need to change repair it into the licence repair man , you may not be worry for the fees coz its only affordable and easy to repair you must avoid those who repair shop that needs you large amount of fees..
To all and especially memmory24k thanks for the suggestion and the time to response to my query.
I have manage to find the actual fault and it is the cradle faulty.
The problem is that the connector on the cradle might have a faulty / coroded soldering.
Did get a new cradle and it charge the my current battery.
Hope the experience I encounter is of help to those experiancing the same problem or might give a direction on troubleshooting.
*** How I found out? I accidentally press hard at the base / bottom of the cradle (somewhere in the center right below the camera connector) with the camera on it (attempting to charge). The charging light light up but if I release the pressing of the bottom of the crdale the charging light goes off. Made a test pressing it for 5 minutes and the battery start charging. Test the camera (after the 5 mins charge) and it is able to power up (previously the battery was totally flat).
