Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Xbox 360 has red ring flashing.wont work - Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
    Problem Solver:
  • 20 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} there is a major problem with the xbox with the RROD for the most part its how you sit your console. do you sit the system standing up or flat on all four rubber grommets? the heat sink sits kind of odd on the console if you have your console sitting up on the side then this can cause problems it will overheat and cause the thermal grease to lighten and loosen which causes space from the gpu/cpu to the heat sink which will cause this "RROD" which is overheat. you see if the console is overheating then that means the processors are not dissipating heat fast enough and in this case the heat sink has been pulled away from either cpu or gpu and you will need to correct that by opening it up and removing the thermal grease thoroughly and apply some well known thermal grease such as zalman or arctic silver compound and lightly but firmly retighten the heat sinks screws to the cpu/gpu. power the console on and it should work with out overheating. now this doesn’t always work if you repeatedly powered it on with this "RROD" which long periods of time will fry the chips and in that case your console is SOL
Posted on Jan 22, 2009
  • S203celest
    S203celest Jan 22, 2009
    Genius:
  • 1,601 Answers
2 Suggested Answers
jtuminaro
  • 56 Answers
SOURCE: xbox360 2 flashing red lights left side of ring
Call 1800-4myxbox
They should repair it
This is a defect that should be covered by warranty.
The soldering has come loose on the CPU.
Posted on Jan 15, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox 360 has 3 red lights and when i turn it on my fans wont work just the 3 red lights keep flashing
This is called the red ring of death and is cause when the Xbox has lack of ventilation and the solder on the gpu melts together, the 2 options you have are to send it in to Microsoft or find someone who doesn't mind voiding warranties and knows the heat gun trick.
Oct 22, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: when i turn my xbox 360 on the power button turns ...
This sounds like the Infamous Red Ring of Death also known as Rrod. This is basically where your circuitry has just burnt out and has died. You can either take it to a Game Shop to mend it or get a new 360. if you choose the new 360 R.I.P Someones 360
May 17, 2010 | Microsoft Xbox 360 Console
Xbox 360 freezing and red ring flashing
Im sorry bout the xbox, trust me i know how it feels for a system to mess up and ive read the Xbox 360 flashing red, is indicating some major trouble is about to go down.
sorry for the bad news.
i hope i have helped!!!!
Jan 05, 2010 | Microsoft Xbox 360 Console
Green start light on x box 360 is flashing red & wont start up ?
This is a problem commonly referred as RRoD (Red Ring of Death) it means your Xbox 360 has a problem. you will have to contact microsoft and tell them you are getting the red lights. They are used to this problem and will help you in a matter of minutes. Microsoft has extended the warranty of ALL xbox 360 machines to THREE YEARS from date of purchase (only for red light problems).
Sep 30, 2009 | Video Game Consoles & Games
Power button on my xbox 360 flashes red and wont play
That's a Red Ring of Death here's more info http://forum.teamxbox.com/showthread.php?t=472553
Sep 25, 2009 | Microsoft Xbox 360 Console
Red light flashes sometimes and not reading disks
Hi carla 0166,
Its not good news im afraid, that red light that flashes on the console is also known as the "ring of death".if one segment is red its not too bad but if its any more it wont work.
To get around this as daft as it sounds you need to overheat the xbox 360.
i know this as it has happened to me also.
simply switch the x box 360 on and then wrap a towel around it and leave for 30mins.
this will overheat the console and when switched back the red light should be gone.
I hope this has helped :)
Sep 18, 2009 | Sega The Club - Xbox360 for XBox 360
X Box 360
It might be Red ring of Death problem, You can either send your Xbox toMicrosoft and wait for 2-3 weeks till you get back your Xbox or you canfix the problem yourself with the help of a DIY fix guide.
Check out the post discussing about RROD problem here: http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/
Hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
122 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
