Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Odor that smells like gas going from the refrigerator
Refrigerator has bad odor. throught it was gas. gas tech came out and did a reading. No natural gas found. all the food was taken out twice and refrig cleaned out. smell still there. still puts out cold air. is there something that can be done to correct this?
  • kkarpinski Mar 23, 2009
    I have a side by side and the service technicians replaced the defrost heater because they stated that was the only explanation...rubber ends on the unit heat up and cause the smell. The problem remains even after the replacement. There is nothing causing it according to the techs and they recommend using baking soda. Didn't work. ALl of our food, even ice cream in cartons and eggs have the smell and the food is ruined. The ice maker was replaced and the ice tastes bad. We are having a second opinion tomorrow and I hope to be able to eat again.
  • 833 Answers
Mold and mildew can cause problems like this. It is even possible that a small animal may have invaded your home and gotten into the box somehow. Cleaning the inside of the box with a dilute bleach solution may help. For continuing odor absorption, place an open container, say a 1/4 cup, of baking soda (bicarbonate of soda) in the compartment. Change as often as once a week. The powder will absorb the odor.
Posted on Jan 24, 2008
Why is there a strong gas odor?
Suggest you turn off the gas supply immediately! and check for a poor connection or other cause. Do not attempt to light the pilot again until the cause of the leak has been found and repaired!
Nov 19, 2015 | Home
A horrible sickly sweet smelling odor blowing out back of refrigerator
would check ur drain lines for food residue that rotted u may need to defrost and clean the drain line in freezer and fridge
Jun 22, 2015 | LG Refrigerators
Sears Kenmore refrigerator odor in freezer?
A quick phone call to Sears or a local appliance service center may be in order. Since the evaporator that cools everything is located inside or very near the back of the freezer and the freezer has the lowest air circulation of the entire refrigerator, I would suspect a small refrigerant leak. Many refrigerants have strong odorizing chemicals added for just this purpose. Natural gas for heating has these same chemicals to warn us of the danger if a leak occurs. If it is a leak it's not dangerous, but very soon you will come home to a warm fridge and thawed food. Prior to that you'll hear the fridge running constantly as it tries to maintain the proper temp.
Mar 09, 2013 | Refrigerators
GAS Odor? Gas dryer smells of gas after it runs a cycle, just replace ignition gas valve assembly, still has gas smell?
Did you also replace the coils on the valve assembly?
Which parts did you replace exactly?
Nov 07, 2012 | Dryers
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
Our Maytag Neptune gas dryer is exhausting a natural gas odor now... This smell only occurs when it has been running for awhile and never when it's turned off. Also, it ONLY smells outside the house via...
The burner is not lighting right...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Odor eminating from freezer
Dead mouse or rat is a definite possibility.
May 04, 2017 | Haier RRTG18PABB (207 cu ft) Refrigerator
My nordyne gas furnace has a terrible odor coming from it. It is not natural gas. It is really bad when the heat is coming through the heat vents and into my home, and it smells putrid and disgusting.
Perhaps a small animal, bird, etc, maybe has fallen into the burners or close by, this often happens you need to have a look for any ...Umm .. foreign matter, in or around your unit, and remove it. There is a product called "Nil-Odor" this removes and neutralise's bad smells.
Mar 02, 2010 | Heating & Cooling
Kerosene odor from natural gas heater. gas co thinks grates break
The odor your referring to usually comes from you recently using an oil based product like paint or wood oil. Until the petroleum based product has fully dried, the open flame will seem to be the source of the odor but are really just intensifying it. If you have a gas range, see if those burners smell similar. Rags in a gas dryer also cause the odor. The gas co. will check for gas or carbon monoxide  only but this odor is neither. Good Luck and please rate my answer if it was helpful.
Dec 30, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Bad Odor in Whirlpool Conquest Refrigerator
put boxes of baking soda opened in the frig. The baking soda will absorb th odor.
Sep 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
4,347 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
