Question about Panasonic SC-AK27 Shelf System
SA-AK27 (AUSTRALIAN VERSION)
GENTS, I HAVE A SA-AK27 MINI HI-FI SYSTEM, IT IS WORKING FINE NOW EXCEPT FOR THE VOLUME. THE SYSTEM ONLY WORKS WHEN PUTTING OUT VERY LOWS LEVELS OF SOUND. IT SEEMS TO GET TO A CERTIN POINT AND JUST CUT OUT, AROUND 40DB ON THE DISPLAY(NOT THE DISPLAY COUNTS FROM 64DB TO 0DB AS IT GETS LOUDER).
DO YOU HAVE ANY IDEAS OF WHAT MAY BE CAUSING THIS PROBLEM, CHEERS
SIMON
You got to much **** hooked up to it
Posted on Dec 29, 2008
6ya staff
SOURCE:
Hi I have SA-EH550 technics HI-fi music system. Start my system low volume no any problems but I adjust volume high after some time system go stop and show error code f61 Please give solutions. Thanks..
On some systems F61 is to do with the fan not working properly, sometimes blocked with dust. On others it's a power amplifier failure. Yours does sound like a power amp problem, but both should be checked.
Sep 26, 2018 | Technics Audio Players & Recorders
Hi everyone I have s Panasonic Sa-AK27 that is stuck on standby mode,the thing is it has been on the box for the past 5years after my dad pased on he was the owner,so now I decided to use It
Very often when left for a long time the Electrolytic Capacitors in the power supply section dry up and cause it to get stuck in standby. The only cure is to replace all the big capacitors in the power supply section.
Dec 22, 2016 | Panasonic Rak-ch944wk Sa-ak27 Sc-ak27...
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
How do you clean a lens in a 5 cd changer panasonic sa-ak27
You should take it out, wet some cotton sticks with WD40 and some ethanol and then clean it with it, the stick must be just slightly wet
Jan 22, 2013 | Panasonic SC-AK27 Shelf System
FI have a cb radio from Hong how do Ichange frequency to suit Australia. The radio is Qishi fm transceiver, QS-368S.Is it possible to change crystals,if they still use crystals
There are versions of this radio on different bands, some versions will not work on the Australian 477MHz CB channels even if reprogrammed.
Reporgramming the radio requires the software and a programming cable. Ask you radio supplier if the software and a cable is available.
If the radio is a version that will work and you manage to reprogram it it may work but will not be legal to use on the Australian UHF CB system because it is not type approved.
Sep 05, 2010 | Radio Communications
Panasonic SA-AK27
Learn to spell first before you call someone a "dumass," *******.
Nov 28, 2008 | Panasonic SC-AK27 Shelf System
Panasonic SC-AK27 Shelf System Logo
294 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
