Question about Car Audio & Video
Clarion ETV100 Code
Can someone help me with the code of my car stereo? It shows a SAFE word in the display
SOURCE: Clarion PU-9317A unlock code
http://www.oobydoo.co.uk do an unlocker it
Posted on Oct 29, 2007
SOURCE: car stereo code input protocol for blaupunkt 520 car audio system
- WHEN YOU KNOW WHAT YOUR RADIO CODE, TRY THIS: I JUST TRIED THIS ON MY 520 IN A HOLDEN VECTRA (1999) AND IT WORKS:
- HOLD DOWN THE 'AS' BUTTON UNTIL YOU HEAR A BEEP, THEN YOU GET THE FOLLOWING DISPLAY:
10 - - - -
- PRESS BUTTON NUMBER 1 UNTIL YOU GET THE FIRST DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 2 UNTIL YOU GET THE SECOND DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 3 UNTIL YOU GET THE THIRD DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 4 UNTIL YOU GET THE FOURTH DIGIT IN YOUR CODE
- HOLD DOWN THE 'AS' BUTTON UNTIL THE STEREO TURNS ON.
Posted on Jun 14, 2008
  • 4991 Answers
SOURCE: CLARION ADZ628R STEREO UNLOCK CODE
To reset , leave SWITCHED ON ...UNDISTURBED for up to 24 hours
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
T
If not then it will only be available from your Main Dealer or a Decoding
Posted on Sep 06, 2009
brado83
  • 106 Answers
SOURCE: wiring diapgram and color code for clarion drx6475
hey hey,
Dont have a diagram but if you wanna know the colours they are
Red - Accessory Power
Yellow - Battery+
Black - Ground/Chassis
Orange/White - Illumination
Blue - Power Antenna
Blue/White - Amp remote wire
Brown - Celluar phone mute lead
Speakers:
Front Right - +Grey -Grey/Black
Frount Left - +White -White/Black
Rear Right - +Purple -Purple/Black
Rear Left - +Green -Green/Black
Hope this helps you out
Kind Regards
Brad
Posted on Jan 01, 2010
Testimonial: "Yes very helpful thanks very much"
SOURCE: SECURITY CODE NEEDED FOR CLARION CAR STEREO
www.radio-code.com/ -
www.radio-code.com/UnlockManu.htm -
floodle.net/extra/ebayinfo/car_radio_decode.html -
Those should sort you out.
Posted on Mar 25, 2010
Forgot security code clarion pu-2859a serial no cl066660345372l
HI ,,CLARION,MODEL .PU-2859A(C)...SERIAL NO;;CL066660021608C..CODE ???PLESE.
Aug 19, 2011 | Car Audio & Video
Code on a clarion car stereo
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Apr 16, 2010 | Car Audio & Video
NEED SECURITY CODE FOR CLARION CAR STEREO
why would you need a security code for it? In any case, give clarion a call and they can give you the default key,... unless someone changed it, in which case, its a dead duck.
Mar 25, 2010 | Car Audio & Video
Mar 25, 2010 | Clarion DB245 CD Player
I have got a vreg corsa with a stereo that hasnt got a display.could u please tell how to put the code in because the numbers only go to 6 on the stereo and in the code there is a 9 and 7 please help the...
Find your Blaupunkt instructions on this free Code Entry website.
http://www.radio-code.co.uk/code-entry-help.php
The exact instructions will depend on the radio model.
If your display is NOT working and you have the CORRECT code then the usual method to enter the code "blind" is to ADD 1 to each digit.
So Code 1234   would be entered "blind" as 2345
A typical Blaupunkt with a separate display is the model CAR300
Below are the Code Entry Instructions for that model
(Don`t forget to ADD 1 if you are entering the code "blind".)
 INSTRUCTIONS TO ENTER A BLAUPUNKT CAR 300 (no display ) RADIO CODE
Switch the ignition key ON
Press and hold
AS button *  and the  ON button at the same time
Display Shows SAFE  then goes to 10 - - - - with a
"Beep" from the speaker
Press Preset Button "
1 "repeatedly until the 1st Digit of your Code is displayed
2" repeatedly until the 2nd Digit of your Code is displayed
3" repeatedly until the 3rd Digit of your code is displayed
4" repeatedly until the 4th Digit of your code is displayed
If the display  now shows the correct Code number then
Press  Button
AS  and hold to Enter and if successful  there should be a "Beep" from the speaker and the radio should switch on
Nov 14, 2009 | Car Audio & Video
Car stereo Code
hi, go on ebay and buy the radio unlock codes less than a fiver
Apr 17, 2009 | Clarion DB245 CD Player
T
Apr 16, 2009 | Clarion ADZ628R CD Player
Need code for a clarion pu-9971
i believe the only way to get this code is you have to call clarion and talk to someone from tech services and they will walk you through the steps in resetting the code.
Feb 16, 2009 | OEM Systems Car Audio & Video
Car Audio & Video Logo
188 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
