Question about Frigidaire ATF6000ES Front Load Washer
My new Frigidair front loader
My new frigidair affinity washer just makes a humming noise when I turn it on. I won't spin or fill with water. It's brand new I haven't even got to use it yet. My husband took off the bolts on the back that he was suppose to but I don't know what could be the problem. No the water isn't off. We checked it several times. The water is definately on.
  • prtybrws Jan 21, 2008
    I'm having the same problems. But my washer isn't under warranty. It just stopped working. I have checked the water supply hoses as well as the water supply and both are fine. My washer is 2 years old.
  • 447 Answers
Wow it sure sounded like the water was turned off. There should be no problem getting a tech out soon to see whats going on why it wont bring the water in. It sounds like maybe the door lock isnt working?? Is the strike broken on the door?? I take it it wont spin on its spin only cycle??just return it to place of purchase. If you need any other assistance let me know, reply to your old posts so i can be notified you wouls like more assistance.
Posted on Jan 15, 2008
My Affinity front loader works fine but shuts down early at last 6 min no spin soaking wet cloths
Hello James Banks - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit. Thanks for allowing me to help you.
Apr 10, 2013 | Frigidaire Affinity ATF7000E Front Load...
Error code 20 on an affinity frigidaire
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 23, 2012 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
137 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
