Question about Refrigerators
Water dispenser in fridge door
Hi, GE model # gsl25jfpcbs , has water dispenser in door, makes a click sound when actiated but no water comes out,, Icemaker works fine, water gets to it to make ice,, cant seem to figure it out, please help thanks David Z
  • 7 more comments
  • davidz Jan 20, 2008
    It actually wored, had to wait the full 24 hours, now a few days later I guess it froze up again,, any ideas on how to keep it unfrozen?
    thanks David Z
  • davidz Jan 21, 2008
    thanks , how do I e-mail you to find out what the water heater kit is called? or part #
    thanks David Z
  • Anonymous Feb 04, 2008
    I'm interested by this heater kit 'cause I have the same Pb
    Thanks
    [email protected]
  • Anonymous Feb 23, 2008
    Same problem with GE monogram 42. ice maker works fine, water dispenser not. It does click but no water coming out.
    Same problem with ge monogram 42. ice maker works fine, water dispenser not. it does click but no water.
  • jasrich Dec 03, 2008
    Same problem - GE Monogram side-by-side, ice maker works, water dispenser keeps freezing up. Usually throwing out accumulated ice solves the problem but it has reoccuring more frequently and, today, throwing out the ice didn't work.
  • Anonymous May 03, 2009
    GE side by side fridge will make and dispense ice, but no water. I hear it click, but no water comes out. If frozen line, what does one do?
  • Anonymous Mar 23, 2014
    No water comes out of the door's water dispenser. The ice dispenser is working fine.
    Water is working for ice making and the ice dispenser is dispensing ice but no water comes out of door dispenser.
    New Friend:
I have a 42" GE monogram and the outside control pad is not working. any clues y
Posted on Jul 25, 2011
  • 447 Answers
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
[email protected]
Posted on Jan 15, 2008
  • joey  shearer
    joey shearer Jan 20, 2008
    Yes GE has a heater kit available email me for the bulletin explaining it. Buy it from any appliance part retailer or
    www3.sears.com
    www.GE.com
  • joey  shearer
    joey shearer Jan 21, 2008
I have same problem with GE monogram 42. ice maker works, water dispenser not. It does click but no water. Help.
Posted on Feb 23, 2008
6ya staff
SOURCE:
I've had a GE Profile side by side (model # GSS25SGPCSS) with in door water and ice dispenser for approx. 6 years. This week the in door water dispenser stopped working. I removed and replaced the filter...
I have the same fridge and the water line freezes up in the door on a regular basis. I have to use a hair dryer and slowly wait for it to melt. It takes about 30 minutes and then works fine for awhile. It has become quite a habit that I'm not thrilled about. Don't waste your money replacing the board or anything else. GE was no help and I'm now shopping for a new fridge bc of this issue. Needless to say that it won't be a GE! Hope this helps.
Oct 09, 2010 | GE Profile Performance 25.2 cu. ft....
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Side-By-Side GE Fridge Won't Supply Water
Sounds like a frozen line ... press on the inside door lisen to see if there is ice inside defrost the freezer check if water will flow ... if stainless steel door there is a heater kit you can put in... if plastic you will have to replace the door.
Dec 15, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Feb 02, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
1,398 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
