Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Installing battery
I do not see any instruction on installing the battery
  • Bill 6 Jan 15, 2008
    I do not see the installing battery in the manulal
  • 48 Answers
The battery on a SD550 is a 3L model, and it goes in one way.
The bottom of the battery has a set of copper looking contacts, and inside the camera in the battery compartment is a matching set of copper contacts, all you need to do is insert the battery to match the contacts and you should be good!
Posted on Jan 15, 2008
6ya staff
SOURCE:
How do you check ballistic voltage
PDF EVO Battery Instructions - Ballistic Performance Components
https://www.ballisticparts.com/pdf/BT0071B-instructions.pdf
starting procedures" video on our website: www.ballisticparts.com. WARNINGS ... your vehicle has trouble starting, check voltage of the battery and recharge the ...
Evo Battery Instructions - Ballistic Performance Components
https://www.ballisticparts.com/batteryInstruct.php
Congratulations on your purchase of a Ballistic Performance Components ... If your vehicle has trouble starting, check voltage of the battery and recharge the ...
[PDF]INSTRUCTION MANUAL - Ballistic Performance Components
https://www.ballisticparts.com/pdf/BT0071A-instructions.pdf
Please check voltage before installing to insure that your battery has at least 13.2 ...13.2 volts, please charge the battery according to the charging instructions ...
Feb 09, 2016 | Mitsubishi Televison & Video
Where is the sim card placed and installed my new phone didn't come instructions
remove the battery cover and battery
the sim card normally fits in a slot under the battery
Dec 31, 2015 | ZTE Cell Phones
How to setup ge 99916 wireless mouse
Instructions
    • 1Hold the mouse in your hand, press down on the battery compartment cover (the back of the mouse) then slide it off.
    • 2 Insert two AAA batteries into the mouse. Make sure the positive and negative terminals match up with the diagrams inside the battery compartment.
    • 3
    • Replace the battery compartment cover.
    • 4 Connect the USB receiver to a USB port on the computer. The computer will acknowledge that a new device has been installed and you will be prompted to install the software.
    • 5 Insert the software installation disc into the optical drive. Follow the instructions provided by the installation wizard to install the software.
    • 6 Press the link button on the receiver, then turn the mouse over and press the link button on the mouse. The mouse is ready for use.
Jun 07, 2014 | GE Wireless Optical Mouse
Doesn't work Is there a battery?
All of these non-contact voltage testers require a battery. On this one, its located under the pocket clip assembly at the top. Consult the manual page 3 here: http://www.kleintools.com/sites/kleintools/files/instructions/NCVT-1-Non-Contact-Voltage-Tester-Instructions.pdf for instructions on how to install the two AAA batteries.
Dec 04, 2013 | Klein Tools Klein Ncvt-1 Non-Contact...
Installing battery instructions on A7100 android phones
Refer the video for battery replacement instructions. It's in a different language but it will help showing you the procedure.
May 08, 2013 | Android Cell Phones
Installation instructions for mercury 20hp electric start conversion
remove flywheel and install flywheel ring and charge coil install start button and neutral switch and starter , and landyard switch battery cables and a battery
Feb 11, 2012 | Boating
I'm using a kwikset smartcode lock. When I follow the directions, holding the lock button while inserting the battery pack, instead of two beeps after a while, I get a beep, then 5 seconds later a long...
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. I did not see anything about an insertable/removable battery pack or the need to hold a lock button while changing the batteries. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Apr 26, 2011 | Kwikset 907 907-11P Venetian Bronze Smart...
I need instructions for a Everstart ES20LBS motorcycle battery
What type of instructions do you need. Just make sure you install the battery with the correct polarity and install the positive side first, the negative side last.
Good luck
Steve
Oct 12, 2010 | Harley Davidson FXDWG - FXDWGI Dyna Wide...
Alarm and chime does't work after installing a new battery?
There is sometimes a need to re-set the watch after installing a new battery and there may be an instruction to "short battery to case" inside the watch.
Was the battery changed by a technician or yourself? If the latter, the seek the advice of a friendly local watch repairer, who may be able to sort it out for you.
I have read the instructions for a watch that looks like your (in the Amitron range) but there was no useful information given.
Sep 14, 2010 | Armitron Two Tone Sports Watch
Need instructions to install a new battery
1. If you have a dell computer, visit www.support.dell.com. 2. Enter services tag and click on manual.
or if you have any other computer, please visit the manufacture's website, and in the search box, type in, Manual.
Feb 10, 2010 | APC Back-UPS Office 500VA (BF500) UPS...
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
