Question about Canon NP 6035 Copier
E065 error I get an error code on my np 6035 copier Error E065! I cant cant get any solution of this..can some one help.. really appreciate it.
  • funding Jan 22, 2009
    We get E065 many times a day which asks us to turn the machine off and back on. Of course there is always a jam, because the machine has stopped working mid-stream! What is the error? and how can we fix it?
    Thanks.
E codes are usally associated with copy jams check all paper drawers for paper jams and display panel indicator to see what area is lit and then check that area for trapped paper.
Posted on Jan 15, 2008
6ya staff
SOURCE:
Canon NP 6035 Error code &switch on and off
What is the error code is displayed on the control panel???
Oct 01, 2011 | Canon NP 6035 Copier
E065 canon NP 6030
If I rember correctly, Your transfer roller unit is arching out. I would first clean off the loose toner in the unit & from the seperation unit. You will need to remove the transfer roller unit. If that dos not clear the code you will need to replace the transfer roller unit. Good Luck
Mar 10, 2011 | Canon NP 6035 Copier
CANON NP 6035 The error code E224
Bagaimana cara mengatasi error e224 ???
Salam Sukses By KBG.
Feb 27, 2011 | Canon NP 6035 Copier
Trouble E065 WITH CANNON 6230
ERROR E065-Composite Power Board or DC Controller
Jan 11, 2010 | Canon NP 6230 Copier
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
Oct 01, 2009 | Canon NP 6035 Copier
Cannon NP6035
check here for the code: just look for the code, doesn't matter what machine type, they use the same code for different types of models
http://www.copier-help.com/copier-help/ecs/canon/eccgp200.html
Jul 23, 2008 | Canon NP 6035 Copier
Fault
change your m/c s fixing/heating unit lamps
Dec 19, 2007 | Canon NP 6035 Copier
Troubleshoot
Désolé car j'ai le méme problème et je trouve pas de solutions, un code d'erreur E065 puis ca bloc avec un bourage, c'ent ambétant car ca me fait perdre beaucoups de papier. merci de m'aider
Nov 27, 2007 | Canon NP 6035 Copier
Canon NP-6035 persistent E002
There is a heating problem connected to the fuser. It could be the heater lamp or thermal switches. Lamp is most likely.
Aug 27, 2007 | Canon NP 6035 Copier
Canon NP 6035 Copier Logo
651 people viewed this question
Clive
Clive
old marine
old marine
Ekse
