Question about Nikon Speedlight SB-800 TTL Flash
Flash doesn't flash
I connected the sb800 to my d70 and it doesn't flash - changed batteries - no help - even if I take the flash off the camera and push the flash button 0- no flash but the ready light blinks and then goes off. No flash though.  Same on camera ready light flashes but no flash.  I was told to reset flash by the two button system ( how the heck do you that)?  I'm new with this camera so could you tell me where and what the mode button is.  HELP I really need the flash -  THANKS FOR THE HELP!!!
    Champion:
    Scholar:
  • 216 Answers
I think you've posted this problem already.
Anyway please see Jan 15, 2008 SB800 doesn't flash.
Check that first.
Posted on Jan 15, 2008
Hello I have an sb800 nikon flash (4 years old) that has just started to act up....seems as my shoot goes on the flash seems to get very warm and wont always fire... Im using energizer rechargeable 2500mah...
Are you shooting those 20 pictures in rapid succession? If so the flash is saving itself by shutting down. If that is not the case, check your batteries with a battery charger to see if one may be weak causing a strain on the others. Call Nikon 1-800-645-6689
Aug 26, 2010 | Nikon Speedlight SB-800 TTL Flash
Sb800 firing without pressing shutter release
sounds like a short in one of the circuit boards, most likely one or seveal of the ribbons and boards will need to be replaced to correct the problem. Send in for repair expect to pay up to $200 for a Nikon factory overhaul
Feb 21, 2010 | Nikon Speedlight SB-800 TTL Flash
D70 and SB800 sync issue
On the D70 custom menu (Pencil icon), there is an option to Synchronise shutter speed below 1/60 second (the default).
See 21 Shutter spd.
You can select anything from 1/60th to 30".
Aug 26, 2008 | Nikon D70s Digital Camera
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
Berrie Smith Camera Repair
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb800 doesn't flash
Let's force the flash to fire:
nstalls four fresh batteries.
Turn on flash, do not connect to camera
Wait until flash is ready
Get a small wire with insulation and strip both ends about 1/8".
With one end of the bare wire lead, touch/hold CENTER TIP
Contact(silver pin from flash).
Make sure flash head is not pointing at your face.
With other end touch bare wire to OUTSIDE Contact (silver on
outside of hot shoe that rides into camera hot shoe rails-this is ground).
Flash should fires, gets a flash out of the flash tube.
If not, you have flash problems.
You most likely hurt the flash by using the dome filter on top of flash.
Over 80% photographers are doing this way when shooting flash photography. And 95% for wedding photographers.
This will shorten the life of the flash.
Even more with that adapter parked onto the flash.
Hope they are helpful to all photographers.
Suggestions or comments,
atdlee@netzero.com
Jan 15, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb800 will not flash
To reset the device, hold down the "MODE" and "ON/OFF" buttons at the same time for about 3 seconds.
Hopefully that will do the trick. if not you cant contact me for further help!
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
SB800 firing but not syncing??
I had that same problem with the SB600 and the SB 800. Solutions; get a new one. After about a year of usage the sb600 started giving me that problem. It flashes but it does not sync. It still works as a remote unit, but not mounted on the camera. The SB800 just went to a coma last weekend. No sync at all, not even as remote unit, no strobe function, just a bright flash, when triggering the test button with new fresh batteries, it flashes at max power once and takes around 7 seconds to recycle. No multiple flashes at all. I had to buy a new one.
Jan 09, 2007 | Nikon Speedlight SB-800 TTL Flash
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon Speedlight SB-800 TTL Flash Logo
239 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
