Sounds like the CPU is overheating. Try cleaning with canned air. On the bottem of the laptop you can see a fan with laptop off and battery removed use a whole can of air to clean it. wait 5 min. replace battery and try normal start up. listen for the fan to come on if it doesn't the fan is bad and needs to be replaced
Hope this helps
Please leave feed back
Testimonial: "Great help Thank You !! Will try the approach I hope it helps. !!"
When a computer/laptop shuts down and won't power up straight away and then able to boot up after the computer cools down, then this indicates a thermal overload problem.
This is usually caused by a faulty fan and or the heat-sink and fan is clogged with dust, therefore it doesn't cool the CPU and causes it to overheat and shutdown. If this is not fixed the eventually the CPU will fail.
Check the fan to see if it spins freely, if not replace the fan. Check the heat-sink/fan and remove and vacuum the dust off these components.
Testimonial: "Thanks for the prompt reply"
This an AMD Turion, so I though they normally run that hot. I have been having these issues from the very beginning ( intermittently with varying periods -- now it is too frequent 10 mins). Can I as a noivice do all the above ? Replace Fan, Heat Sink dust cleaning ? The problem has increased now it even shuts down in safe mode or when left in the Bios mode !!
