Question about Kodak EasyShare DX6440 Digital Camera
DX6440 LCD screen is Black
The camera LCD screen is black. Can see some faint image on it. Can still take picture as usual. How do you make the LCD screen bright like normal ? Thank you for your suggestion
  • Larry Wielen Apr 19, 2008
    MY SCREEN IS ALSO BLACK BUT I CAN STILL TAKE PICTURES WOULD BE NICE IF IT WORKED LIKE IT WAS DESIGNED TO
  • mikesank May 11, 2010
    I have the same problem. Hopefully the firmware upgrade I down loded from the help side will fix it.
As I suspected, the flexible circuit board which connects the fluorescent back light to the power source was severed. Although it didn't appear broken at first, the LCD came on as I poked the flex board. I removed a small amount of insulation and reconnected the two copper leads. Problem solved.
The flex board I speak of is an amber colored ribbon; it can withstand high temperatures and is quite durable. There are two copper leads embedded in the ribbon. One end of the ribbon is sealed within the LCD, the other end terminates in a locking surface mount connector. You can unlock the connector by pulling back on the little brown latch. If you have a severed flex board, be extremely careful in repairing the connection. Once you begin removing the amber coating, it becomes fragile.
Posted on Aug 07, 2008
  • 3 Answers
I had this problem when turning the camera to take vertical shots. Turns out my polarized sunglasses obscured the image when shooting vertical. Solution: take off my sunglasses.
Posted on Aug 16, 2008
Can the lamp be replaced for a Polaroid TLX03210B
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
Dec 18, 2012 | Polaroid Televison & Video
Black screen
If its LCD get the room very very dark and turn on--with a flashlight near the screen look closely at the screen to see if you see a very faint image of the picture or not---Most LCD flatscreen's (not Plasma) use what is called a back light to light the screen--light source.
If a faint picture can be seen that way the light is not on.
Dec 17, 2012 | Sceptre Televison & Video
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
The view screen is black and you can't see what you're taking the pic. Battery is ok
If camera shows Menu item or any on-screen display in LCD but no live view to take picture then it can be either aperture problem or defective ccd imager.
And if you do not see any display icon in LCD then of course LCD section is bad or LCD back light is Off for some reason. Try to see faint image in LCD if it is totally blank by pointing good amount of light with flash light or some thing.
Oct 16, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera LCD - black pictures
When I take a picture, there will be know image. Black. I went into the "share" and the image is black. I kept my smart card and the other images are ok but the knew ones are black. Camera has power. I took the smart card off. Still the problem, black. Took the old images off and took some more shots. All black!! MMMMM?
Sep 02, 2008 | Kodak EasyShare DX4330 Digital Camera
LCD monitor
Hello!
Sounds like your backlight may be out, unless you're still able to see a faint image when the LCD is "black"...?
If you can still see a faint image of what your camera is pointed at, I would assume your LCD is bad. In which case you could purchase a new one on darntoothysam.com for ~$60 or have them do it for you for ~$85.
Nov 19, 2007 | Canon PowerShot A75 Digital Camera
LCD is black
you can see images clearly? but no Menu items show is that what you mean? This would indicate a firmware malfunction. If you see nothing at all on the screen but only 'ghost' images then the back light has blown. Try first of all with the camera on tapping gently at the base of the casing in the region of the screen- this is where the connectors to the main board are. Contact The Minolta support team. If you are getting nowhere - I suggest the next camera - repairs are not usually an economic option if at all.
Jun 27, 2007 | Konica Minolta DiMAGE E500 Digital Camera
Kodak EasyShare DX6440 Digital Camera Logo
126 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
