1999 63" sony big screen problem...
My tv just shut off the other day while I was watching it. It has worked fine until then. It will not turn back on. Can you help?
Thanks
mickaya21@yahoo.com
  • mickaya21 Jan 18, 2008
    KP-61V80 The TV will make a clicking sound and there will be a very small flash of light in the back of the TV down by the floor when I plug it in. The standby light will stay on but I can not turn the power on. Someone recommended I check the fuse but I couldn't find one.
    Thanks so much!
    mickaya21@yahoo.com
Buy your tvs from www.thebigscreenstore.com and you wont have anymore problems!
Posted on Sep 21, 2010
  • 8,617 Answers
What mode number is your Rear projection unit? I need the model number to even begin to help you with it.
Posted on Jan 18, 2008
  • Sonny Berry
    Sonny Berry Jan 18, 2008
    Okay on that model there are 3 fuses located on the G board they are F60l 6.3 amp @ 125V
    F651 Multipart 4 amp and F652 Multipart 4amp . Look the G board over you will find these fuses. Does your set flash any code. The flash of light your talking about could be a short. Let me know if the standby light is falshing count the sequence then let me know.
My Samsung smart TV shuts off on it's own then turns back on, we have unplugged it and waited 1 min the turned it back on and it seamed to work fine. The next evening it did the same thing, I left it alone...
Have you determined if there is an low activity screen saving feature? It may be similar to my Sony which will turn off the screen after a specific time (approx 1hr) if you don't press a control key. It assumes there is nobody watching so it saves power.
Aug 28, 2013 | Samsung Televison & Video
Sony WEGA KV-34XDR960 works all day then about 1 or 2 am it shuts off & standby light blinks 6 or 7 times. I turn it back on but it eventually it shuts off again any where from 5 minutes to a couple of...
U have a thermal/intermittent issue. Given the age of the set and fact that other areas are now going, I think the cost effective way is to replace the set.
May 02, 2017 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Our tv recently displayed projection lamp was about to go out and needed changed, so i purchased a new lamp assembly and replaced it. tv worked good as new for a few days, then in the middle of watching tv...
Most often, I find when servicing these televisions, the lamp has failed but it was due to poor fan circulation. This television has at least 3 if not 4 fans. If you take off the back and find these fans are filled with impacted dust, the fan may be causing the failure. Also check to be certain your door safety switch is making good contact. These tips should ber of assistance but check your fans. A clean inside of a tv is a happy tv!
Jul 11, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Screen Flicker then tv shuts off
please re solder  first all parts specially in hot area, and observe if problem still occur, then next is replace filter capacitor. observe also too hot parts and check for change value resistor.
Feb 25, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Shuts off by itself, then makes weird noise in back of TV
have a tech check your flyback conection in side the set some times thay come loos during shipment.
regards
daniel.
Jan 05, 2009 | Sony KV-32S42 32" TV
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Magnavox TV will no longer turn on
Does it beep .. or anything? Does the front LED come on?
May 24, 2008 | Philips Magnavox 51MP392H Rear Projection...
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
