Question about Apple iPod touch
I touch wifi not connecting !!!!!
I followed the fix suggested on your site but still can't connect .
I have the connection bars full on the i touch but cannot connect ......?
  • 97 Answers
Youhave to be closer to a connection than you think this thing works like a computer you have to be in range and close.
Posted on Jan 15, 2008
I am not connected to wifi all the time it cuts out
The following site mentions several factors that may be causing intermittent connection. I suggest you fix the ones that may be fixed. Check what may be checked. Some may not be fixable.. Is your intermittent connection experienced more often than not in a particular environment? Does that require you be blogtcked from a direct line of sight to your router? Is the blockage, if present, significant in terms of wiring or electronics.
Loss of Wifi Connection High Speed Internet Customer Service Verizon
Sep 14, 2017 | The Computers & Internet
What is error code 651?
I have fixed mind through following steps, OS Windows 7. This works if you can still use cable internet, so that system can download the driver.
In my case there was no wifi utility, no connections detecting, no bars IIII.
Solution:
Please note it is mostly to do with your network drivers, if you go to device manager under the network adapters, you will see network controller marked in yellow. Dont worry.
To make your wifi connection work please complete the following steps:
Goto:
Device manager > trouble shooting ( column 3 , second last row )
Now under " Hardware and Sounds" heading go to configure a device.
It will start trouble shooting automatically, and try to download and install the right network control driver.
My system is using: Realtek PCIe FE Family Controller and after downloading the driver. I have now following installed.
Realtek RTL8191 SE802.11 b/g/n Wifi Adapter ( this was missing )
Now when I go back to device manager I have both are functioning and after reboot I automatically connect to the wifi. So everything is fine.
So my advice to all whatever make is your PC / OS , do go to device manager and try trouble shooting.
For those who have found this solution helpful, please email me: manny.nlAThotmail.com
Jan 21, 2011 | D-Link DI 514 Wireless Router (DI-514)
I cannot connect my ipod touch to my router how do i connect it?
First you'll need to turn on your Wi-Fi.
1. Choose (Settings) then (WiFi) then (turn WiFi on)
2. Set iPod touch to ask if you want to join a new network: Choose (WiFi) and turn (Ask to Join Networks) ON or OFF.
Then you'll need to join a WiFi network (your D-Link for instance)
1. Choose (Settings) then (WiFi) then wait until your D-Link shows up in the list of networks.
2. Select your network and if you have a password for your router make sure you type it. (networks that require a password have a lock icon next to it) then tap (join)
Once you join a WiFi network manually, iPod touch will automatically connect to it whenever the network is in range. If more than one previously used network is in range, iPod touch joins the one last used.
When iPod touch is connected to a WiFi network, the WiFi icon in the status bar at the top of the screen shows the connection strength. The more bars you see, the stronger the connection.
Good Luck
Dec 25, 2010 | D-Link DIR-600 Router
Mine and my sisters ipod touch keep saying invalid argument everytime we try to get on the internet on it. If you know what wrong please anwser.
Hello there!
I might be able to help you on your case.
When you are connected to the wifi on your ipod touch do the followings
Settings>>wifi>>(you will see a blue arrow next to the wifi signal you are connected) tap on the blue button>>you will see couple of lines full with numbers.
If you see anything full less then 4 line then do these procedures.
After you press the arrow button you will see at the top part saying forget this netwok. Tap on that and then try to re-connect with the wifi.And then do the above procedures.
If it still doesnt solves your problem then this is because of your wifi connection.Try to reset your wifi connection or use another connection. Hope this will help you.
Jan 18, 2010 | Apple iPod touch
Cant connect ipod touch to wifi
try updating the firmware to 2.2. if that does not work.
You may have to reset your Modem + Wifi Router
In my case, if I bring a new device home, my router won't allow it to connect because it is not recognize. Unplug both router and modem, plug them back ( router 1st ) and try again.
This issue never happens to me at home now but it still happens when I go out to bars or restaurant that offers wifi.... Turning off and on the wifi in your ipod touch a couple times usually fixes it.
Sep 25, 2009 | Apple iPod touch
Wifi isnt working in ipod touch
make shure you chose the connection on the ipod
Aug 20, 2009 | Apple iPod touch
My touch shows that I have a wifi connection, but i cant use it.
All you have to do to the ipod is go to settings, wifi and make sure its turned on in the same place you should see a list of wifi networks you can connect to just tap the one you want and the ipod will do its thing your done, but if you done all that and you ipod doesnt go online says connected but wont access the net, my guess is the wifi router you mite have some prob with that, make sure the internet ethernet cable is pluged into the modem plug not the numbered slots after this you should be good to go unless your wifi modem is new if so some req you to plug it to your computer via ethernet cable to program it first! Hope this helps
Jul 13, 2009 | Apple iPod touch
How to connect HTC p3450 to wi-fi network, what r the setting?
After you turn on your wifi, you can simply follow the first 3 steps of this (http://iris.nyit.edu/oit/academic/FAQ/faq/2wireless/20026/20026.pdf) tutorial. After that, you should see your home wifi name in the list (as in the photo in the tutorial.). You should first connect to a network from this list (possibly with a wifi password), then it should connect automaticly evertime you swtich on wifi. After you have successfully connected to a wifi, you should see the wifi icon changes in the task bar. Hope this helps.
May 16, 2009 | HTC Touch P3450 Smartphone
New ipod touch will not connect to wifi
Did it ever connect to wifi before? I had the problem today and when it picked up the network connection I hit "forget network" and the let it reload, then I re-entered my password (to the network) and it connected perfectly :) Hope this helps you.
Dec 27, 2008 | Apple iPod touch
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
