Question about Intertherm P3RA-048K Air Conditioner
Heating problems intertherm mobil home ac and heat works but sometimes red light on thermosat comes on outside unit fan motor runs but fan dose not seems to work fine except for that is there aproblem that needs to be fixed
  • 447 Answers
It sounds like the unit is going into a defrost cycle, which is normal for heat pumps and means all is working ok when it gets around 35 or colder they start to do this more often when the red light goes back off , the outdoor fan should come back on. You may also notice steam (may look like smoke) coming from outdoor unit. Is that what happens??
Posted on Jan 15, 2008
I have a Intertherm heating and airconditioner unit and the ac works but when I go to turn on heat I get a humming noise only 2009 or 2010 Mobile home unit
turn power off and put red wire in with white wire at tstat and turn power on. if heat works it's possibly a configuration issue or a tstat issue. keep us posted.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Nov 03, 2017 | Intertherm Heating & Cooling
MY outside unit will not kick on now I just had it filled and seem to not want to kick on so I'm thinking it a short or the new t-stat that was just replace over the winter heat side works fine
Turn breaker off. Wire nut the red, green and yellow. Turn breaker on. Check outside. If unit is running either your tstat is not setup properly or it is bad
Jun 17, 2016 | Intertherm Heating & Cooling
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
The unit will come on in house but fan is not on outside you can hear it clicking like its trying to and blowing warm air
Sounds like you need a new Run capacitor or hard start kit (includes the capacitor), but you should have it checked by tech
Aug 21, 2013 | Intertherm Heating Cooling System 15kw...
I have a 4 year old intertherm AC /Heat pump...all works ok - but sometimes in summer or winter - when the inside unit cuts off - the unit outside still runs and whines and sorta sounds like a grinding in...
Has it always made that noise? If so then I would think that after 4 years and no problems that it is nothing to worry about. If it is something new then turn it off and call a service tech to look at it. I am leaning toward the service tech.
Jun 15, 2011 | Heating & Cooling
I have an intertherm central air unit in my mobile home that does not change fan speed when I click the fan speed switch. I've checked the fan relay which is good and energized in the ac mode which should...
You may ahve a bad switch but sometimes when they are worked on the servicrman bypasses the switch. Fan speeds are color coded black high blue med yellow med high and red low. Just for your info. Russ
Aug 16, 2009 | Heating & Cooling
Heat pump 5 ton package unit
You have two of your t-stat wires that are shorted out. Disconnect the wires at both the unit and t-stat. Take two wires at a time and ohm them out. If you have continuity those are the shorted wires. Substitute them for two different colored wires if you have two wires that are currently unused. If not you will need to pull new wire. Please answer back to say if this works or not.
Jan 18, 2009 | Heating & Cooling
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
96 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
